I hope I'm not late for work!
Old Apr 3, 2015 | 10:24 AM
  #761
Atomic's Avatar
I have a gauge for that
You guys say that like its a bad thing
Old Apr 3, 2015 | 12:13 PM
  #762
GM1697's Avatar
still waiting on chopped finger pics lol
Old Apr 6, 2015 | 10:04 AM
  #763
badz24s's Avatar
formerly b4vwannabe (2/4/2012)
I'm waiting to see if the logs look good
Old Apr 6, 2015 | 11:24 AM
  #764
sprayedenali's Avatar
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA HAHAHAHAHAHAHAHAHAHHAA
Old Apr 6, 2015 | 11:48 AM
  #765
Atomic's Avatar
I mean, they look decent so far
If only yall couldve seen Chris's face when he was with me hahaha
Old May 16, 2015 | 01:21 PM
  #766
Atomic's Avatar
Well, actually made some progress.
My plan is to slap it on as is with the 6 rib big pulley and do some testing. Then pull the blower off, install a spacer im designing, install the 8 rib kit and small blower pulley, change the heads to some other cnc L92s I have and change the cam.
Old May 16, 2015 | 01:47 PM
  #767
BlackGMC's Avatar
Resident Retard
Uou gonna bump up the compression with the head swap?
Old May 16, 2015 | 02:26 PM
  #768
Atomic's Avatar
Yea slightly because ill probably use normal ls9 gaskets instead of the custom 0.080" ones on there now.
Old May 16, 2015 | 02:32 PM
  #769
Jeebalow's Avatar
What is the spacer you are working on? Will you be adding a bigger heat exchanger and need the extra height?
Old May 16, 2015 | 02:45 PM
  #770
GMCtrk's Avatar
You still expect this to be able to do a 6 second 1/8th, correct?
