I hope I'm not late for work!
Old Oct 6, 2016 | 11:33 PM
  #1591
GM1697's Avatar
Originally Posted by Atomic
Just need to repair Greames little plastic nitrous controller holder thing that melted in the sun
Yeah **** man. I owe you. Want the CADD file and see if your dude could cut you one outta aluminum?
Old Oct 8, 2016 | 01:13 AM
  #1592
Atomic's Avatar
I have a gauge for that
So previous best with the 2.9" pulley was 7.47@96 with a 1.72 60'. Tonight with the same tune and setup just with my 1/2" plate installed and the 2.7" pulley my best of 2 runs was 7.29@97 with a 1.65 60ft and I would guess the temps about the same. That was the run without trying the nitrous. Second run I tried it with the 50 shot pill (I think) in there and bank 1 didnt like it at all. My meth pressure sensor wasnt reading for some reason so that and with it missing at WOT I called it a night since it was an hour drive back home. I actually took it down to 80% throttle so the nitrous cut off at about mid track since it was a little lean, still went 96mph though. Lot of tuning to do on this thing...
Heres a video of the second launch going from a dead idle
Old Oct 8, 2016 | 08:40 PM
  #1593
1FastBrick's Avatar
Custm2500's Rude Friend
Just Curious. Were you late to work?
Old Oct 8, 2016 | 09:57 PM
  #1594
Atomic's Avatar
Well, I have started to shift my schedule 30 minutes because the traffic is so much better then, so, yes, I guess I am late to work.
Also interesting to note without the nitrous I gain about 30 degrees to the end of the 1/8th, with the nitrous and meth going it's only about 12 degrees.
Old Oct 8, 2016 | 09:59 PM
  #1595
1FastBrick's Avatar
I think you should do a twin turbo set up instead...
Old Oct 8, 2016 | 11:24 PM
  #1596
settlemoore's Avatar
^this
Old Oct 9, 2016 | 12:45 AM
  #1597
AkSSS's Avatar
I third or fourth or whatever, the twin turbo thing! Do it!
Old Oct 9, 2016 | 03:08 AM
  #1598
GMCtrk's Avatar
Trying to drag race with the blower is an honorable effort. That's all i will say.
Old Oct 9, 2016 | 01:15 PM
  #1599
Vortec350ss's Avatar
Hah! Lots of haters.
How much total timing are you running at 12-14psi? what meth nozzles are you running when not spraying nitrous?
Old Oct 9, 2016 | 02:58 PM
  #1600
Atomic's Avatar
Meh twin turbos are overdone. A single 88 will be more than enough to go faster than 4wd will like and certainly way more than would be practical on anything but slicks.
Timing is around 16-17psi, no meth pre blower anymore, pump is hooked directly to fuel solenoid.
