I hope I'm not late for work!
Old Jan 11, 2014 | 12:32 AM
  #261
smokeshow's Avatar
Mod with training wheels
Originally Posted by Atomic
I put my stethoscope on all the injectors and they sounded fine...
Richard, last I heard you weren't a doctor..
Old Jan 13, 2014 | 10:00 PM
  #262
Atomic's Avatar
I have a gauge for that
I pulled all the injectors and they all looked fine...tested them with a power supply and all click fine and all show the correct resistance across the coil. Sent them back to FIC anyway to be checked out. Also bought a set of stock injectors to test against.
I upgraded the underhood lighting and holy ****, these are 10 times brighter than the ones that were there, I think they are brighter than my worklight
Old Jan 13, 2014 | 10:19 PM
  #263
oakley6575's Avatar
Dayum. You better get SPF 45 if you plan to work under the hood
Old Jan 16, 2014 | 08:53 PM
  #264
Atomic's Avatar
Found my problem I think....cylinder 7 has 54% leakdown and I can feel it leaking out of the exhaust port...I should have had a valve job done while I had the engine apart. Shucks.
Old Jan 16, 2014 | 08:58 PM
  #265
Chevy_King1500's Avatar
glad you found it, just sucks it has to come back apart
Old Jan 17, 2014 | 04:16 PM
  #266
BlackGMC's Avatar
Resident Retard
Damn that sucks man. At least it is not the short block.
Old Jan 18, 2014 | 09:47 PM
  #267
Atomic's Avatar
So found something interesting....I put a pressure gauge in a block to my meth nozzles and played with the pump a little bit measuring pressure at the nozzles. Long story short, its interesting how this kit works (alky control). The pressure varried so fast at, lets say, between 120psi and 30psi it broke the needle on the gauge! Probably 20-30 times a second. Pretty impressive actually. Gonna retry it with a liquid filled gauge.
Old Jan 18, 2014 | 09:54 PM
  #268
silver-mod-o's Avatar
Hunt&Fisherator
Would be cool to put a transducer there and log it and actually graph the pressures.
Old Jan 18, 2014 | 10:02 PM
  #269
Atomic's Avatar
I am trying to create a transfer function between nozzle pressure and intake pressure, since the controller references intake pressure anyway. If I have that then there is no reason to log it since nozzle pressure (and therefor flow) are a function of boost pressure. I have some data points so far but the needle was so unsteady it was hard to get an accurate reading so ill need to retest them all. With that said, 1 and 2 14gph nozzles empty the tank and fill up a bucket fast!
The goal in this is to see if the pump can support 3 14gph nozzles without dropping pressure.
Old Jan 18, 2014 | 10:14 PM
  #270
Hunt&Fisherator
If you were closer I'd supply the meth for your studies haha.... I have basically an endless supply of 100% meth.. I keep a few gallons handy to de-ice natural gas lines but that's about all I use it for.
It's cool to start fires with too!!!
