I hope I'm not late for work!
Old Oct 21, 2019 | 03:21 PM
  #1941
1FastBrick's Avatar
Custm2500's Rude Friend
A # 4 size mesh is .185 hole size. This is nylon plastic and stainless also rated for suction.
My only concern with the other one is the that its zinc plated and it will corrode. It also might need a few holes in the lid as well.
Old Oct 21, 2019 | 03:35 PM
  #1942
1FastBrick's Avatar
What is your hose rated at for vacuum?
Old Oct 21, 2019 | 05:44 PM
  #1943
1FastBrick's Avatar
So the one we use at work looks like the "Miniature Suction Strainer with 1-1/2 Female Unthreaded Pipe Connection" Style from Mcmaster carr.
I just could not get a spec on what mesh they actually use. The biggest pump Flows 23 GPM on the clean side and the chiller is rated at 90,000 BTU
The # 20 size mesh it the largest mesh on that style filter which is .0328 -.0331 and # 4 mesh is .185 -.187 depending on whos conversion chart you look at...
Any way food for thought....
Old Oct 21, 2019 | 05:46 PM
  #1944
Atomic's Avatar
I have a gauge for that
Are you gonna stop complaining if I use that hose instead? ��
The strainer I posted is a lot bigger so it'll be less restriction. I'm not worried about small stuff, just big pieces of ice. May powdercoat it so it doesn't rust.
Old Oct 21, 2019 | 05:59 PM
  #1945
1FastBrick's Avatar
Talking
Nope...
If we can suck closed the normal reinforced PVC hose that is not rated for vacuum at 23 GPM in 80* weather. What will happen at 50GPM???
My thought was that if you blocked part of that strainer, it might become restricted. Part of why I thought a few holes in the top of it might be beneficial. Enough restriction can cause the pump to cavitate. Also should vent the cooler so it doesn't suck itself in.
It's all big science experiment to me...
It's your truck, do as you wish.
Old Oct 21, 2019 | 06:05 PM
  #1946
arthursc2's Avatar
Im learning because I plan to build an ice box for my MR2, so you 2 keep going, I still have things to learn lmao
Old Oct 21, 2019 | 08:27 PM
  #1947
smokeshow's Avatar
Mod with training wheels
If we can suck closed the normal reinforced PVC hose....
I bet you could.
Old Oct 21, 2019 | 08:44 PM
  #1948
1FastBrick's Avatar
Thumbs down
Originally Posted by smokeshow
I bet you could.
Old Oct 21, 2019 | 08:59 PM
  #1949
Atomic's Avatar
I bet you could.
I think you guys really underestimate how stiff this damn hose is. I can jump up and down on it at 260lb and still not crush it. That other hose is appealing since I need to make a couple tight bends though, seems to be more flexible than what I have.
Old Oct 21, 2019 | 09:09 PM
  #1950
1FastBrick's Avatar
He is just projecting his homosexuality here because he misses George...
Do you know what the durometer of the hose is?
