I hope I'm not late for work!
Old Apr 23, 2017 | 09:36 AM
  #1741
Atomic's Avatar
I have a gauge for that
Yes they are stainless. The old vbands I used were mild, but not male/female, and they were not stuck together so that was nice.
Old Apr 23, 2017 | 09:54 AM
  #1742
03sierraslt's Avatar
Cool, ya I've used the male/female that were mild steel before and they are a bitch once rusted.
Old Apr 23, 2017 | 03:02 PM
  #1743
kbracing96's Avatar
Just a tip, if any of those nuts on the stainless bolts or t-bolts are stainless, change them out for zinc coated nuts. The ss nuts on a ss bolt will gall and seize up very easily!
Old Apr 23, 2017 | 03:12 PM
  #1744
wretched73's Avatar
always use never seize when using a stainless bolt and a stainless nut
Old Apr 23, 2017 | 03:32 PM
  #1745
Petraszewsky's Avatar
Is that the muffler I gave you? It's from a 2008 if so. I'm surprised there wasn't any packing material in there.
Old Apr 23, 2017 | 03:58 PM
  #1746
Atomic's Avatar
The one I cut up is from an 07 tahoe I think. The one I got from you is actually on my truck now
I put some antisieze on the vbands during final assembly, so I hope that works.
The fuel pressure thing continues. The FP gauge in the cab has never been "right" as far as pressure goes, but is consistent so I just go with it. I hotwired my main pump on and looked at my mechanical gauge right on the regulator and its 20psi. I adjusted the regulator all the way down, 20psi. All the way up, 20psi. I pulled apart the regulator to inspect the diaphragm and it looked perfect with no rips or tears or strain from what I could tell. Put it back together, still 20psi. Unhooked the after rail hose to the regulator and ran it to a gas can to test pump flow and it came out like a garden hose so I think flow is good.
Not sure what else to try but a new diaphragm for the regulator. It is strange all of this just by replacing the fuel filter (with the correct aeromotive part and same micron rating) and a 1ft section of hose.
Old Apr 23, 2017 | 08:01 PM
  #1747
BlackGMC's Avatar
Resident Retard
Those mechincal gauges on the regulator go bad all the tume. I have gone thru 4 of them. I have tried tons of brands. Surprisingly the summit cheapo one has lasted.
Old Apr 23, 2017 | 08:47 PM
  #1748
Atomic's Avatar
Truck is harder to start, electric gauge reads lower than it usually does (whatever the number is), mechanical gauge is lower, I cant hear the pump loading up like it usually does, and the adjustment screw on the regulator doesn't do anything. So 5 things tell me the regulator is bad so that's what I am going with
Still struggling to figure out what happened though. Only thing I can think of is when the hose came off during running it somehow damaged the diaphragm even though it looked fine to me.
Old Apr 24, 2017 | 09:06 AM
  #1749
sprayedenali's Avatar
i still have the 4" dual magnaflow muffler exhaust i got from you when you decide to change it up again next week...
Old Apr 24, 2017 | 10:31 AM
  #1750
Atomic's Avatar
I have a DISO big magnaflow sitting in storage also but wanted to try the stock mufflers route this go around. I've had a lot of mufflers.
