C3 build
Old Sep 8, 2011 | 04:37 PM
  #171
AndysC3's Avatar
Originally Posted by GMCtrk
Milling the heads costs flow and i dont think going from 9.5 to 9.8 will make a significant change, at least while n/a.
Regarding the plug, no luck in getting it. Havent heard from the guy, but kbracing gave me the name of someone else that may have it.
stock 317 have a 72cc chamber, WCCH heads have a 74cc chamber do to the porting. Milling .025 will take about 4cc off and make it a 70cc chamber. Or I could take .01 to get it back to the 72cc chamber.
Old Sep 8, 2011 | 04:43 PM
  #172
GMCtrk's Avatar
You're LQ4, right? With 74 cc chambers the compression will probably be 9.2 or so (guesstimate based on 9.4:1 stock w/72 cc)
I would call Richard and ask him, he would know best whether sacrificing air flow for a slight bump in compression would be worthwhile.
Old Sep 8, 2011 | 05:18 PM
  #173
AndysC3's Avatar
yes, its a LQ4. wouldnt any bump in compression help. could do .030 for a bit more but thats the most That I'd be willing to go. Would get a set of 243s if I wanted more.
Old Sep 8, 2011 | 05:22 PM
  #174
GMCtrk's Avatar
Something else to consider is once you mill you're compromising the integrity of the head, which doesn't matter on an N/A setup, but with the procharger you're planning on it may be important. Again, I'd just call Richard. He will know better than anything you can read on here.
Old Sep 8, 2011 | 05:33 PM
  #175
AndysC3's Avatar
Yea, I tried to call but no one answered. Must be busy making some awesome heads. I sent him a email. well see what he says.
Old Sep 8, 2011 | 05:42 PM
  #176
GMCtrk's Avatar
Look what I found
Spares and Repairs | fishtuning.com
Old Sep 8, 2011 | 05:43 PM
  #177
BigRed Cummins's Avatar
Milling .025" off a virtually solid block of aluminum is going to have negligible, if any, affect on the structural integrity. Most modern cars are made of 22 ga sheet metal, which is .0299" to put it in perspective.
Old Sep 8, 2011 | 05:46 PM
  #178
AndysC3's Avatar
Awesome find. Now order it, have it overnighted, and TUNE MY TRUCK!!! lol.
Old Sep 13, 2011 | 06:46 PM
  #179
AndysC3's Avatar
so need a new cam
Option 1: EPP Blower Cam 232/240 .595/.608 115LSA
Option 2: Comp Ls-R 227/235 .614/.621 113LSA
Option 3: Custom Grind
I cant seem to find option 1 online. Leaning toward option 2. option 3 will delay my cam swap. What do yall think?
Old Sep 13, 2011 | 07:09 PM
  #180
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
What rpm does your converter flash to right now?
