C3 build
Old Aug 20, 2011 | 11:26 PM
  #151
AndysC3's Avatar
just wanna make sure that this is the atf that I need.
got 4 gal.
Old Aug 22, 2011 | 01:41 AM
  #152
AndysC3's Avatar
Thanks to the help of Jake(Smokeshow) and (Michael)GMCtrk, the trans is in. Had a few issues with the starter. and we cracked a spark plug and had to make a quick run to autozone. got the new plug in and it fired up and ran smooth. took it out for a little test drive and man its nice. Didnt want to get on it too much, until the trans is broken in. It flash stalls right around 3700-3800. Gonna have to get a retune and get to the track.
Old Aug 24, 2011 | 08:43 PM
  #153
AndysC3's Avatar
So looking for some header studs, Found these,
LS1, Ls6, Ls3, Ls7 Lsx, Stainless Steel Header Studs | eBay
What do yall think?
Old Aug 26, 2011 | 09:33 PM
  #154
AndysC3's Avatar
some pics of the install.
getting started
Transfer case is out
the jinga tower that we made
New trans with the old bellhousing. those bellhousing bolt were a pain to get out.
Getting the Trucool 40K lined up
Old Aug 27, 2011 | 01:24 AM
  #155
AndysC3's Avatar
so a few questions for the experts...
1) Head bolts? Stock, ARP bolts, or studs
2) Head Gaskets? GM MLS 6.0L or LS9
3) Timing chain? truck has 75k and has be taken wot quite a few times.
4) Rocker arms? stock, stock with trunion upgrade, or get some studs for my HS rockers
Anything else I should look into?
Old Aug 27, 2011 | 04:10 PM
  #156
AndysC3's Avatar
Just sold my old trans. May be doing the head/cam sooner that I thought
Old Aug 27, 2011 | 05:10 PM
  #157
GMCtrk's Avatar
how much you get for it?
we can do the cam next weekend
Old Aug 27, 2011 | 05:21 PM
  #158
AndysC3's Avatar
300, also sold my old Rockford Fosgate R1 subs and amps for 125, Only thing Im undecided on is the head gaskets. I dont know when Im off again. they are switching my work schedule, working 4 days then get 2 off, so I will rarely have weekends off. Going to try and take some leave at the end of next month. maybe then. Ill let you know.
Old Aug 27, 2011 | 05:41 PM
  #159
GMCtrk's Avatar
stock 6.0 head gaskets, although I thought I heard you mention a procharger, so I guess the LS9's wouldn't hurt if you want to spend the money on them. You'd need to see what the different in compressed thickness is though.
Old Aug 27, 2011 | 05:49 PM
  #160
AndysC3's Avatar
6.0L head gasket: 4.02" bore .051 thickness
LS9 head gasket: 4.100" bore .051 thickness. so its about the same.
