C3 build
Old Jun 16, 2013 | 08:50 AM
  #1251
AndysC3's Avatar
Well I was going to sell it. But I was going to keep working on it. But all of that's useless now. On my way back from town to get e85, which they were out of, did a short 3rd gear pull. 55-105. Let out and started logging a lot of knock. It died on me as I was pulling onto base. Got it started and something is deff broke. Limped it back to my house and the motor siezed about 3 houses down from mine. Afr was 10.5-10.6. Still showing 19* timing so that may have done it, iat was 70-72* So I'm most likely going to part out the truck. And get a dd for the family
Old Jun 16, 2013 | 09:23 AM
  #1252
Tydriver's Avatar
Man that sucks.. Sorry about your luck.
Old Jun 16, 2013 | 01:48 PM
  #1253
AndysC3's Avatar
Hopefully is just a push rod, spring or lifter and the motor is fine. If so I will replace the broken parts and trade in the truck
Old Jun 16, 2013 | 01:58 PM
  #1254
GMCtrk's Avatar
Were you running dual or single springs? When my spring let go it ran pig rich but never seized. The valve never broke off.
If you snapped a spring and the valve head snapped off in the cylinder that piston will be toast.
Old Jun 16, 2013 | 02:03 PM
  #1255
AndysC3's Avatar
It has dual springs. Patriot gold dual springs. And it was running richer than normal. Around 13.5 at 70 and vac went to 5"
Old Jun 16, 2013 | 02:32 PM
  #1256
AndysC3's Avatar
Just looked at my log. 11.6 max psi. Starts at 9* goes up to 13* at the shift and afr was about 10.6-10.9
Old Jun 16, 2013 | 06:05 PM
  #1257
smokeshow's Avatar
Mod with training wheels
I figured the transmission would give before the engine did.
Old Jun 16, 2013 | 06:13 PM
  #1258
AndysC3's Avatar
Yea. I figured that too. I was making about 500 when it went. And it was 5-10 sec after the wot run. Got .8* knock then 5 more seconds then it was showing knock like crazy. I'm really starting to think broken valve spring. Just need to get time to crack it open to find out
Old Jun 16, 2013 | 06:17 PM
  #1259
03sierraslt's Avatar
Didn't you say it was seized?
Old Jun 16, 2013 | 06:45 PM
  #1260
GMCtrk's Avatar
Yeah, if it seized I'm thinking there's a hole in a piston.
