C3 build
#1242
I was around 400hp NA, trapped 99mph with your tune shifting at 6400 rpm. It got a lot faster when I turned it up to 6900 but I never got it back to the track with the new shift points. but if your saying that Im only making 515 then I only gained 100HP at 12psi. that doesnt add up to me
#1244
#1245
I cant spend 550 on a balancer. I may be able to swing the 90 for a new 3.4" procharger pulley.
so a full bolt on 6.0 only makes 350hp na? thats heads, cam, tbss intake, full exhaust and tune.
#1248
so Since I cant get methanol here Im going to fill alittle E85 in the tank. Going to start with 5-6 gal and fill the rest with 90. and tune from there. eventually work my way up to 45-50% blend of E85/90. have the commanded afr of 11.3 with 11.2 in the max torque areas and reduced the timing t run a max of about 17*. Also getting a 3.5" pulley to swap on if I get greedy. can I run jut water in the meth system? just set the grain all the way down and have it start spraying around 5psi and full around 14 psi? or set th max higher so Im not spraying too much?
