Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
Old Oct 12, 2014 | 12:11 PM
  #1621
custm2500's Avatar
Ph.D. in HUBRIS
Yes but from what I understand an engine on methanol runs much cooler then one on pump gas or race fuel. That is why I asked the question if it helps keep the engine cooler and you wouldn't need all the cooling modifications.
Old Oct 12, 2014 | 12:38 PM
  #1622
oakley6575's Avatar
If you keep it fat enough on alcohol, you'll never get heat in the motor.
Old Oct 12, 2014 | 01:37 PM
  #1623
custm2500's Avatar
Ph.D. in HUBRIS
That is what I thought. But it would take two 100 lb. per hour injectors per cylinder at this hp? That is a lot of fuel.
Old Oct 12, 2014 | 09:09 PM
  #1624
oakley6575's Avatar
Well stoich is something like 6.2 or 6.4 or something with methanol so it takes more than twice the amount of fuel to combust vs gasoline...
Back on topic. OP, when do you hope to have the engine back together? Will it be down for the winter?
Old Oct 12, 2014 | 11:32 PM
  #1625
Blown06's Avatar
8 Second Truck Club
I doubt 2 100lb inj. per cylinder would be enough. Probably run twin 235's or something like that.
I'm hoping that I can at least get one test session in before the end of the year. Engine guy wants to re dyno it on an engine dyno again, but this time with the blower on it. So that should be fun.
Old Oct 17, 2014 | 11:48 PM
  #1626
Blown06's Avatar
8 Second Truck Club
Just a heads up, I'm gonna be selling the following components as a package deal. I'll post a classified with pics later.
Moser converted 5-lug hubs and rotors
Belltech 2" drop springs with buckets
Single adjustable QA-1's
Calipers ground to fit a 15" bogart
Thinking I'm gonna ask $500 for it picked up.
Old Oct 21, 2014 | 11:11 PM
  #1627
Blown06's Avatar
8 Second Truck Club
Engine builder is moving along a lot faster than I was expecting. Good thing.
Pistons and heads should be going to polydyne by the end of the week!
Old Oct 22, 2014 | 12:08 AM
  #1628
oakley6575's Avatar
Is the coating done for safety? Does it help with heat or what?
Old Oct 22, 2014 | 11:01 PM
  #1629
Blown06's Avatar
8 Second Truck Club
He claims to have seen some suppression of detonation issues in other engines he has built. Just about everything we are doing is to prevent detonation and to help contain combustion better.
Old Nov 1, 2014 | 11:44 PM
  #1630
Blown06's Avatar
8 Second Truck Club
Engine guy is moving right along. Heads are all set up for cooling and welded up. I think they are at greg goods for a final freshen. 1/2" head stud conversion is done on the block and the pistons are done.
Once the heads get back from greg's, everything will go to polydyne and then it should be as simple as a hone and throw back together.
I do hope I see some power improvements......Jesus busted off an 8.80 and other guy from the valley went like 8.79 I believe. Then Spike reset the record with his twin turbo entry at 8.05. Hoping I can land somewhere in the middle.
