95 RCSB to LQ4/4L60e Swap (56k Heavy)
Old Feb 12, 2012 | 12:47 AM
  #21
BlueMagicSS's Avatar
Cool project. This thing is gonna screw! Is it a stock LQ4?
yes stock LQ4, The Owner wanted a truck that would pass CA Smog
-Matt
Old Feb 13, 2012 | 12:44 AM
  #22
Starts up but immediately dies. Almost like VATS is shutting it off. only idles for a second at the most. No matter if I hold the throttle or not. Any suggestions?
I've swapped out the PCM with another one, I was told one was tuned out. The other PCM had no spark, so I put back the original one that I was using.
Checked codes, getting U0107 Pending and 2 other O2 sensor codes (the Precat 02 on the driver's side is the wrong connector so it's unplugged)
I know that there is no fitting on the intake for the fuel pressure regulator so I know it's getting full pressure from the pump, but I don't think it would be enough to completely choke out the engine that much.
Fuel Pressure is 50psi KOEO and 58psi KEOR
Any ideas?
-Matt
Old Dec 14, 2012 | 07:25 AM
  #23
06murder's Avatar
Might be the vats. But you check for unhooked grounds wires?
Old Dec 14, 2012 | 09:56 PM
  #24
oakley6575's Avatar
Old thread
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
OHsixLS3
Dec 27, 2016 09:30 AM
greedygenius
Sep 3, 2015 06:51 AM
creekrat
Aug 2, 2015 01:27 AM
