95 RCSB to LQ4/4L60e Swap (56k Heavy)
This 95 is a project that I'm working on for another member on here. It started life as a 350TBI/4L60e and I'm swapping in an LQ4/4L60e. Trans will be updated with the Gen III/IV style 4L60. Using a Nelson Performance Harness, Transdapt Adapter Plates, and everything else needed for a Smog Legal Setup. I'll go into detail with the swap and take pics along the way. I've put a build thread up on a couple other Boards, but not on here yet. But here goes...
http://i35.photobucket.com/albums/d1...s/101_3290.jpg http://i35.photobucket.com/albums/d1...s/101_3293.jpg Getting ready to pull the engine http://i35.photobucket.com/albums/d1...s/101_3295.jpg Got a little help from a friend http://i35.photobucket.com/albums/d1...s/101_3297.jpg Me removing the last little connections http://i35.photobucket.com/albums/d1...s/101_3299.jpg http://i35.photobucket.com/albums/d1...s/101_3302.jpg http://i35.photobucket.com/albums/d1...s/101_3308.jpg http://i35.photobucket.com/albums/d1...s/101_3314.jpg All Gone... http://i35.photobucket.com/albums/d1...s/101_3322.jpg http://i35.photobucket.com/albums/d1...s/101_3326.jpg |
LQ4
http://i35.photobucket.com/albums/d1...s/101_3331.jpg http://i35.photobucket.com/albums/d1...s/101_3332.jpg Transdapt Mounting Plates http://i35.photobucket.com/albums/d1...s/101_3333.jpg Dropping it in for a test fit http://i35.photobucket.com/albums/d1...s/101_3335.jpg Looks Right at home http://i35.photobucket.com/albums/d1...s/101_3336.jpg http://i35.photobucket.com/albums/d1...s/101_3337.jpg Put the intake on to see how it would look http://i35.photobucket.com/albums/d1...s/101_3339.jpg Looks like a pretty good fit... http://i35.photobucket.com/albums/d1...s/101_3340.jpg http://i35.photobucket.com/albums/d1...s/101_3342.jpg http://i35.photobucket.com/albums/d1...s/101_3343.jpg http://i35.photobucket.com/albums/d1...s/101_3344.jpg http://i35.photobucket.com/albums/d1...s/101_3345.jpg |
Made a little progress, haven't had the chance to post up yet, but here ya go... I removed the old wiring harness for now until I figure out what needs to be removed and what needs to stay. I also pulled the engine back out to change the oil pan gasket and bolt on the pickup tube and windage tray. Also had to modify the TransDapt Adapter bolts so that they would tighten all the way and not hit the block itself. After that it was time to drop the engine back in and figure out this wiring mess...
Pulled the pan off, took a quick look at the bottom end... looks pretty good http://i35.photobucket.com/albums/d1...p/101_3347.jpg A bunch of sludge in the pan, some leaves, and a Styrofoam packing peanut... http://i35.photobucket.com/albums/d1...p/101_3350.jpg All cleaned up (After a bunch of degreaser and brake clean) http://i35.photobucket.com/albums/d1...p/101_3354.jpg Bolted up the windage tray and installed the oil pan http://i35.photobucket.com/albums/d1...p/101_3355.jpg Transdapt Bolts before I cut them... http://i35.photobucket.com/albums/d1...p/101_3356.jpg After the bolts were cut http://i35.photobucket.com/albums/d1...p/101_3358.jpg |
All bolted on and Ready to drop in...
http://i35.photobucket.com/albums/d1...p/101_3364.jpg http://i35.photobucket.com/albums/d1...p/101_3367.jpg Intake and Coil packs on... http://i35.photobucket.com/albums/d1...p/101_3368.jpg New and old Wiring Harnesses http://i35.photobucket.com/albums/d1...p/101_3369.jpg Wiring MESS... http://i35.photobucket.com/albums/d1...p/101_3371.jpg Getting it in order... http://i35.photobucket.com/albums/d1...p/101_3373.jpg A little better.... Still a ways to go... http://i35.photobucket.com/albums/d1...p/101_3374.jpg Anyone know what this plug goes to?? http://i35.photobucket.com/albums/d1...p/101_3376.jpg Where did you guys splice in these connections?? http://i35.photobucket.com/albums/d1...p/101_3377.jpg |
You've got a heck of a project going on. Looks like fun
what r u going to do about ur A/C?
this thing is going to be sick when its done!
Engine looks like 05 or newer. What about the harness??? Need to know so I can tell you what that plug is from. Also what are the wires that are just cut that your reffering to???
Originally Posted by BOWTIE-TIL-I-DIE
(Post 4847574)
(Post 4848197)
