03 rcsb tubro 6.0,4l80 FS/FT
Old Jul 30, 2015 | 07:38 PM
greedygenius's Avatar
Default 03 rcsb tubro 6.0,4l80 FS/FT
Dayton ohio $17,500 Needs front bumper I'm in the process of finding one normal hood chips but overall good shape will consider trades c5z,c6,ls swapped stuff,g8,cts v maybe other stuff I'm just bored with it and want something else. 03 Silverado 1500 rcsb clean title Has heat ac wipers ect can be daily driven Ls 6.0 370ci lq4 stock crank Callie's rods Diamond Pistons Arp 2000 head studs and rod bolts Tick performance stage 2 turbo cam Ls7 lifters Trick flow pushrods Stock 317 heads ported 80# injectors Ls2 drive by wire TB Eldebrock pro flo intake & fuel Rails 10 gal fuel cell under bed Walbro 450 Magnum t76 turbo True boost 2 boost controller log style header tial 38mm WG 50mm Bov Snow performance water meth kit Detroit tru track locker 4.10 PTC 3300 converter 17x9 and 17x7 race Stars New 275/45/17 ET street R Aem boost and A/F gauge Double din touch screen
Old Aug 1, 2015 | 03:02 PM
Forgot to add the new Trans to the list
2003 2WD 4l80e with 12 o clock bell-housing bolt and rear Trans cooler port
Borg Warner high energy clutches
HD intermediate snap ring
Valve body recalibration kit
34 element sprag
Dual free direct drum mod
New seals and bushings
Old Aug 3, 2015 | 07:57 PM
Go5.3tt06's Avatar
how fast that your truck go since u have 4.10 gear on turbo also what mpg look like.
Old Aug 4, 2015 | 08:24 AM
Mpg isn't great maybe 12-15? It goes thru the traps at around 5800
Old Aug 15, 2015 | 02:35 AM
Old Aug 29, 2015 | 09:45 PM
mohamedalkobaisi's Avatar
Registered User
Is it still for sale?
Old Aug 30, 2015 | 09:25 PM
Yes it is
Old Aug 30, 2015 | 09:26 PM
Old Aug 31, 2015 | 01:26 PM
JordanH's Avatar
Restricted
Haha bad *** truck man! You drive that thing out to El Paso and you can pick out 20,000 in furniture from our store to take home with you!
Old Aug 31, 2015 | 10:07 PM
Go5.3tt06's Avatar
Badass. I wonder how you like being have 4.10 on turbo feel fast or something. Give me idea because I got 4.11 on mine. Plan put turbo in since I have turbo kit sit here
