95 RCSB to LQ4/4L60e Swap (56k Heavy)
This 95 is a project that I'm working on for another member on here. It started life as a 350TBI/4L60e and I'm swapping in an LQ4/4L60e. Trans will be updated with the Gen III/IV style 4L60. Using a Nelson Performance Harness, Transdapt Adapter Plates, and everything else needed for a Smog Legal Setup. I'll go into detail with the swap and take pics along the way. I've put a build thread up on a couple other Boards, but not on here yet. But here goes...
Getting ready to pull the engine
Got a little help from a friend
Me removing the last little connections
All Gone...
All Gone...
Made a little progress, haven't had the chance to post up yet, but here ya go... I removed the old wiring harness for now until I figure out what needs to be removed and what needs to stay. I also pulled the engine back out to change the oil pan gasket and bolt on the pickup tube and windage tray. Also had to modify the TransDapt Adapter bolts so that they would tighten all the way and not hit the block itself. After that it was time to drop the engine back in and figure out this wiring mess...
Pulled the pan off, took a quick look at the bottom end... looks pretty good
A bunch of sludge in the pan, some leaves, and a Styrofoam packing peanut...
All cleaned up (After a bunch of degreaser and brake clean)
Bolted up the windage tray and installed the oil pan
Transdapt Bolts before I cut them...
After the bolts were cut
All bolted on and Ready to drop in...
Intake and Coil packs on...
New and old Wiring Harnesses
Wiring MESS...
Getting it in order...
A little better.... Still a ways to go...
Anyone know what this plug goes to??
Where did you guys splice in these connections??
Wiring MESS...
