'89 Chevy C1500 5.3 turbo build
Old Aug 27, 2012 | 06:39 PM
  #71
SuperStepside's Avatar
Oh yea the trans dapt plates are for the motor mounts. The motor mounts push the assembly 1 inch back? Im guessing so that you can re-use the stock driveshaft?
Old Aug 28, 2012 | 07:46 PM
  #72
TRD_Tundra's Avatar
Hey man you think you can get me a picture of the feed line.
Old Aug 29, 2012 | 06:02 AM
  #73
LS1FREEK's Avatar
13 Second Truck Club
Yes, although, I bought a longer yoke (I've seen both longer and shorter yokes) an gad to cut about 3/8" off the end to make it fit good and have plenty of travel.
I didn't make it to the shop last night, I'll do it tonight.
Old Aug 31, 2012 | 06:13 AM
  #74
LS1FREEK's Avatar
I has some questions.
Any pics on the intercooler mounting and pipe setup? Also for the tranny crossmember is that a custom made one? Ive seen other people just move the stock crossmember back and re-drill new holes which I was planning on doing.
Forgot about the A2A mounts I made lol, I'll make some more lol
Old Aug 31, 2012 | 06:15 AM
  #75
LS1FREEK's Avatar
From the turbo to underneath the intake:
From the oil supply going up:
Old Aug 31, 2012 | 08:02 AM
  #76
Looks good. I see you notched the core support to get the pipes to tuck closer. Good idea. Is the sway bar on the truck in this pic? Looks like you'll have good ground clearance when you get it on the ground.
Old Aug 31, 2012 | 08:29 AM
  #77
LS1FREEK's Avatar
Nope, I'm not using sway bar lol, I was digging through some of my older pictures and found this one, kinda shows the brackets.
Old Aug 31, 2012 | 09:31 AM
  #78
03regcab sierra's Avatar
[QUOTE=LS1FREEK;4982882]Nope, I'm not using sway bar lol, I was digging through some of my older pictures and found this one, kinda shows the brackets.
does it ride better or worse without the swaybar? ur build is comin along alot faster than mine is
Old Aug 31, 2012 | 10:00 AM
  #79
vicalma03's Avatar
Hood pins ?
Old Aug 31, 2012 | 11:30 AM
  #80
LS1FREEK's Avatar
It rides the same or mabe a little smoother
Originally Posted by vicalma03
Hood pins ?
Yup!
