'89 Chevy C1500 5.3 turbo build
Old Aug 9, 2012 | 04:20 PM
  #51
03RCSB's Avatar
I got that same oil line kit from trick but since our flipped manifold turbos are so far away the lines ended up being way too short. I ended up with another 18" (i think) of feed line with an AN union and a whole new return line.
Old Aug 10, 2012 | 05:43 AM
  #52
LS1FREEK's Avatar
13 Second Truck Club
I tested mine yesterday, If I run it underneath the intake it'll be plenty long so I think that's what I'll do.
Old Aug 10, 2012 | 06:01 AM
  #53
LS1FREEK's Avatar
Updates!!
These are uncleaned welds, I still have alot of work to do!!
Crossover:
Down Pipe, LOTS of clearance, plenty for a 4"!!:
And the rest: And yes I'll be running a down pipe for my wategate too.
Old Aug 11, 2012 | 04:53 PM
  #54
TRD_Tundra's Avatar
Originally Posted by LS1FREEK
I got a Trick Performance (one of our vendors on the right hand side of the page) turbo oil line kits. You wont be able to return your oil to the oil cap unless your turbo will sit higher than the cap because the oil return is gravity fed. Unless you buy a return pump, but I see that being entirely unnecessary. Im guessing the reason you wanted to do it this way is because you don't want to tap the oil pan, well an easier alternative would be to just tap the bottom of the front timing cover and put your return line there.
I'll be getting a 4l80e swap so since the tranny is out might as well tap into the pan. Were exactly did you tap in on the pan?
Old Aug 11, 2012 | 05:06 PM
  #55
LS1FREEK's Avatar
Look at post #28 of this build.
Old Aug 11, 2012 | 05:25 PM
  #56
TRD_Tundra's Avatar
That's the drain right? And the feed?
Old Aug 11, 2012 | 09:05 PM
  #57
SuperStepside's Avatar
So much room for activities.
Old Aug 12, 2012 | 09:20 AM
  #58
LS1FREEK's Avatar
Very true!! I see a bigger/forged motor in my future with a bigger turbo and DP lol
Old Aug 12, 2012 | 09:22 AM
  #59
LS1FREEK's Avatar
Yes, I'll try to get some pics of that too, but I tapped into that little removable cover right above the oil filter.
Old Aug 12, 2012 | 02:49 PM
  #60
mcconditioner's Avatar
Cool project
