2008 yukon build.....Err uh mod thread
Old Jan 8, 2016 | 11:13 PM
  #71
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by Wolftrk99
Hmmmm.... Damn knew i shoulda kept that cam to begin with.... Yeah that a non direct replacement.... It is a lq9/ls1 cam.... 320hp would put me about where i want to be, basically stock.... The production lc9 is dod
See bold above.
Old Jan 8, 2016 | 11:19 PM
  #72
Wolftrk99's Avatar
The lc9 crate engine is a non direct replacement, for a production lc9 dod engine.... I would have no problem running the lq9 (12561721) cam as it was what got the idea for this project in my head to begin with....if i could find an l33 cam that would work too... Just cant find duration and lsa specs on factory dod cams
Old Jan 8, 2016 | 11:21 PM
  #73
1FastBrick's Avatar
Send me a stock dod cam and I will get the specs on it.
Old Jan 8, 2016 | 11:26 PM
  #74
Wolftrk99's Avatar
Ill see what i can do, probably have one later this week.... Lol hell have two on floor right now.... Ill see if theres a dead one available tomorrow...may have a bad lobe or two though....
  #75
Wolftrk99's Avatar
Too bad theres no way to clean up my lq9 cam....
Old Jan 8, 2016 | 11:28 PM
  #76
Wolftrk99's Avatar
In case you missed em...
Old Jan 8, 2016 | 11:54 PM
  #77
1FastBrick's Avatar
It's not so much the lobes but the main journals.
you can re grind the lobes but the main journals would most likely end up under sized and that would not be good.
Old Jan 8, 2016 | 11:56 PM
  #78
Wolftrk99's Avatar
I may clean it up and use it as a table leg or lamp or something....lol
Old Jan 9, 2016 | 04:23 PM
  #79
Wolftrk99's Avatar
What all would be involved in adding vvt to this little project??? I know obviously adding the actuator and vvt cam how hard would it be to run the wires for it and what issues would i run into programming it?? And if anyone has done it how much did it cost?? I ask because i can get a brand new vvt cam for an l96 for less than $100!! Cant see the L96 cam being a bad thing in this 5.3.....then again been known to be wrong before
Old Jan 9, 2016 | 11:26 PM
  #80
1FastBrick's Avatar
I don't think it would be a big deal but I have no experience with those engine.
