**Three6GMC Official Build Thread**
Old Apr 29, 2016 | 02:44 AM
  #381
Three6GMC's Avatar
lol thanks just updated those pics to some I took earlier today. Didn't like how the other ones came out with my brothers camera. Aluminum suspension will be in tomorrow so ill be putting all that stuff in this afternoon and have more pics. As I'm sure you all can tell by now I like to take a lot of pictures lol
Old Apr 29, 2016 | 09:18 AM
  #382
Three6GMC's Avatar
Got the 2014-16 aluminum upper control arms in this morning. I'll try and have all the aluminum suspension on the truck by tonight and have it back on four wheels. New parts are def lighter (46 lbs. lighter) and anything helps to bring the weight of the truck down. Right now with a iron block/22s/half tank of gas its sitting at 5080lbs. For anyone else wanting to swap out to the aluminum parts ill post the part numbers below. Also just a heads up, in order to run the aluminum spindles you need to run the upper AND lower aluminum control arms. The bottom arms and the upper control arm ball joints are bigger and wont work with steel spindles.
Upper Control Arms:
23125969
23125968
Lower Control Arms:
22853474
22853473
Aluminum Spindles:
22842315
22842314
Old Apr 29, 2016 | 11:29 AM
  #383
Vortec350ss's Avatar
Very interesting... would these parts work on an 800? I am starting to think about weight savings myself...
alum front suspension parts and a coil over conversion... hmmmm
Old Apr 29, 2016 | 11:58 AM
  #384
Three6GMC's Avatar
That I don't know... Think the suspension on the 800s is too different so I would think no but hey you know what they say, you can accomplish anything with money time and know how.
Old Apr 29, 2016 | 12:06 PM
  #385
Seems I'm lacking in a few of those depts
...or all of them. Depends who you ask
Either way I love where you head is at! Great work.
Old Apr 29, 2016 | 02:44 PM
  #386
Atomic's Avatar
I have a gauge for that
Did someone say coilovers on a gmt800?
Old Apr 29, 2016 | 09:25 PM
  #387
Three6GMC's Avatar
Well the aluminum 14-16 suspension does bolt right on BUT you do need the aluminum lower control arm since it too has a bigger ball joint. My lowers haven't come in yet so was gonna try to just run the stock steel ones for now but that's a no go. The lower arm is my steel one I just painted it to match for now. No biggie I'll just wait on that and get other things done.
Old Apr 29, 2016 | 09:27 PM
  #388
Three6GMC's Avatar
Did find out something cool today... Unisteer makes some steering joints and shafts that just so happen to fit these trucks steering racks and columns perfect. I test fit this joint and bolts right on but I'm going to need the double joint to make that angle. Might not seem like a big deal but the stock steering joint was twice the size as this one and had a huge protective rubber boot, not good especially since a hot turbo header will be ran right by it. Good for stock but I'm trying to get as much room as I can on that driver side for the turbo header so works perfect for me. Also a plus is these joints and shafts are stainless steel so no issues with heat.
Part Numbers for the shaft and steering joint from Unisteer
23” DD Steering Shaft:
8050520
Double U-Joint 3/4 DD x ¾ DD:
8050900
Old Apr 30, 2016 | 09:25 AM
  #389
Wolftrk99's Avatar
Those joints look alot better than the stock rubber boot....
Old May 2, 2016 | 09:49 PM
  #390
Three6GMC's Avatar
Yeah save a lot of room too. Hopefully when the double joint comes in everything will work as planned. Next days off I'll finish the suspension and the turbo hot sides.
