Head Question for a Gen I SBC
I am building a 406 SBC for MAX TORQUE. I know that a small cam with good flowing heads = big torque. My question is, what heads?
So far I have been looking at AFR 210 cc heads, but I wonder if there is something that flows just as well for a lesser price.
I have pro action heads on my 406, theyhave different runner sizes, i got 230cc runners with 2.08 valves, but i know you can get them smaller. mine were under a grand ready to go, except for drilling the steam holes...
Edelbrock makes a Performer RPM head that runs just under a thousand dollars a pair. For about $300 bucks more your could buy their Victor Jr heads. Of course you'll want to figure out what size chambers you'll need. They have a couple of popular chamber sizes that should fit your combination. The Performer RPM part number is 60719 (70cc angle plug). The Victor Jr. part number is 77619 and has the same 70cc chamber and angle plugs.
Good luck,
Richard
Good luck,
Richard
Thanks for your help guys. I should have mentioned that I plan to run the HOLLEY 4 Barrel TBI system.
Does this give me a little more flexibility in selecting an intake runner size since the motor doesn't have to rely as much on engine vacuum to pull fuel into the cylinders?
Thanks.
Thanks.
I'm not familiar with the Holley TBI system. If the injectiors are located at the ttb, then the system is still a wet flow system and runner size will have some influence on port average air speed. If the injectors are located at the head flange then your dealing with a dry system and there is less sensitivity and more flexability in runner size.
Richard
Richard
If you want low end torque....go smaller intake runners. Such as AFR 180cc or 195cc. Or you can go with a Vortec casting with a little porting and have a ton of low end/mid range torque. With each, you will have to drill for the steam hole if you are using a 400 block. TBI engines have great low end torque already but just don't go to radical. How are you planning on controlling the electronics part of it...GM harness/computer or C950?
Richard
Richard
5.3lSilverado
25
Aug 29, 2016 12:48 AM
