Head gasket question
Old Jul 4, 2010 | 11:54 PM
swift700's Avatar
Default Head gasket question
Could someone please tell me how many cc's difference there would be between a head gasket of .051/4.030 vs .051/4.060? I'm working on my exact compression ratio for my build and need this info. Thanks.
Old Jul 5, 2010 | 09:46 AM
Rick_Vor's Avatar
Only 0.16cc difference.
Use this compression calculator to play around with your build.
http://www.kb-silvolite.com/calc.php?action=comp
For example if I used my 6.0l build specs, going from a 4.030 to a 4.060 HG drops the compression 0.016 points (9.510 to 9.494.
Rick
Old Jul 6, 2010 | 01:57 AM
swift700's Avatar
Thanks. I'm trying to do a 370 build using 62cc heads and am trying to get the compression ratio down to around 9.5:1 but am not having much luck. I've tried different compression ratio calculators and get a lot of different numbers. What components are you using? Head size?
Old Jul 6, 2010 | 04:41 PM
Rick_Vor's Avatar
I built a 6.0l 4.005 hone with Wiseco K444x05 11cc dish pistons, Lunati ProMod rods (used but re-sized), stock crank and a new iron block. The pistons ended up being .004 in the hole so I'm a 9.5 compression with a 65cc AFR 225 heads and .053/4.100 HG.
Rick
Old Jul 6, 2010 | 05:19 PM
swift700's Avatar
OK thanks, using 4.030 bore, 6.100 rods and .051/4.060 gasket, 11cc dish pistons I get 9.4:1 or so but the pistons are .019 in the hole. Do you think this is too far down?
Alternatively I can go with 6.125 rods and get .006 in the hole but the comp ratio would be 9.95:1.
A third option is to go with -25cc pistons, 6.125 rods, .040 gasket and get the pistons .010 out of the hole and an 8.95:1 ratio.
What would be the best of the three?
Old Jul 6, 2010 | 06:39 PM
MARK3406E's Avatar
Might help if you were more specific about your over all goals. All of those would work for differant situations.
Old Jul 6, 2010 | 06:56 PM
swift700's Avatar
I'm building a high-torque engine for towing but would like a reliable truck that's fun on the street. A sleeper, of sorts.
Old Jul 6, 2010 | 11:20 PM
budhayes3's Avatar
PT's Slowest Truck
If you're staying NA I'd get as much compression out of it that I can...I like the 9.95:1 of the three listed...
thunder550
Oct 8, 2015 04:53 PM
dantheman1540
Jul 29, 2015 04:45 PM
BIGD4504
Jul 28, 2015 11:46 AM
bbowerman
Jul 26, 2015 10:57 PM
