Comp XR269HR
Old May 18, 2010 | 01:38 PM
  #21
Vortec350ss's Avatar
Well thats a bummer... haha
Think its possible to run those times with a cam that is a tad more aggressive, but still retains a lot of the characteristics I am after?
Old May 18, 2010 | 01:44 PM
  #22
DV2000NJ's Avatar
13 Second Truck Club
Take a look at the setup I'm running in my sig. Tons of low end, and pulls nicely all the way up to 6200.
This thing definitely has 13s in it once I pull the mud tires off, and remember not to run with a FULL tank of gas.
Old May 18, 2010 | 01:46 PM
  #23
MPFD's Avatar
11 Second Truck Club
I don't think more cam and more stall will be noticed at all. My truck drives like stock with a lot more noise, power, and tire smoke. Your driveablity is all gonna be in your tune. Get a good tune and you'll be able to get away with more on the street. I agree with GMCtrk I wouldn't be scared to spin it harder, your not gonna hurt it.
Old May 18, 2010 | 01:48 PM
  #24
DV2000NJ, Was your tune spot on in that run, I thought I remembered you saying there was a lot left on the table with how it was running?
That cam sounds like its not far from the ball park of where I want to be
Old May 18, 2010 | 01:52 PM
  #25
00ChevyScott's Avatar
Wearin' da big hat
I think the converter is what will be holding you back
Old May 18, 2010 | 05:27 PM
  #26
03sierraslt's Avatar
FYI, I am running a 216/227 114lsa and a 2800 stall (currently about 2500, was stalled at 2800 when i was supercharged) The cam has a slight lope but nothing obvious @ 680rpm idle. I didnt notice any low rpm loss and the mid and top pulls much harder. I am also heavier then your truck because of 4 wheel steer & the Dana 60. If I was going to stay NA I would go bigger then what I have but thats not the plan.
Old May 18, 2010 | 05:28 PM
  #27
budhayes3's Avatar
PT's Slowest Truck
13's are going to be tough with a truck that heavy, but I think you'll be close. I agree with Scott, the converter will hold you back, but I think your converter choice will be perfect for that cam and daily driveability. You mentioned wanting the cam to chop...I don't think that you'll really hear that cam in a 6.0 if the tune is spot on. It will sound meaner than stock, especially to a trained ear, but won't lope very aggressively...you could always turn the idle way down if you want lope lol.
Old May 18, 2010 | 06:27 PM
  #28
03chevyroyce's Avatar
my cam and circleD stall match pretty well. im always pretty near my powerband
Old May 18, 2010 | 08:26 PM
  #29
DV2000NJ's Avatar
On the 14.0 passes, yes everything was running right. I have some exhaust work to do still, but that's really all that was holding it back (other than the heavy mud tires and an extra 80-90 lbs. of gas).
I drive my truck daily, and I'm 100% satisfied with my setup as far as cam/converter go. Tons of low end, and quick enough throughout to surprise people. The converter drives within a couple hundred rpm of the stock converter under light/medium throttle, and flashes right up to 3k when you get on it.
Old May 18, 2010 | 08:47 PM
  #30
budhayes3's Avatar
PT's Slowest Truck
Hmmm, considering that you're running 14 flat with those big mudders on there, maybe high 13's are possible for Vortec350ss with a similar cam and tb converter which should stall around 26-2800 behind that 6.0 I would think...
