402 Teardown
Old Mar 28, 2013 | 10:22 AM
  #41
nonnieselman's Avatar
Originally Posted by custm2500
Wow, that is a bummer!
What about buying a 454lsx? I am sure it isn't cheap but the damn thing should have zero problems and a warranty?
Or how about a dozen LQ4s for the same amount of money..
Old Mar 28, 2013 | 03:21 PM
  #42
Jake99's Avatar
New block, crank, rods resized, and let her eat!
Old Mar 28, 2013 | 07:53 PM
  #43
Atomic's Avatar
I have a gauge for that
Keeping the same block, line hone, new dragonslayer crank, and then let it eat
Old Apr 22, 2013 | 07:37 AM
  #44
lablackbeast's Avatar
doesn't know what quit means
Were you line hone before??
Old Apr 22, 2013 | 08:49 AM
  #45
Atomic's Avatar
yes, of course
Old Apr 23, 2013 | 09:58 PM
  #46
ForcedTQ's Avatar
Thumbs up
Even if I could I wouldnt, this crank is cursed.
On another note...as a thought experiment, what would happen if I put in a stock 3.622 crank with my rods and pistons? "Stroker" pistons have a shorter pin height, but if you combine the shorter height with shorter stroke would you just have a really low compression 6.0? I worked the numbers and it would be around 8:1 SCR...
Wonder if it could take 35psi
Sorry for your troubles but, DAMN, that's what I call taking lemons and making lemonade!
Compound Turbo setup in your future, maybe sequential with a nice small A/R on the little one to get through the low static compression blues quickly???? Pssshhhhh, 35 PSI, lets see 40! I forget, what alloy are your pistons?
Old Apr 23, 2013 | 10:25 PM
  #47
kelsey_canard's Avatar
Are you going back with a 4" stroke crank?
Old Apr 24, 2013 | 12:09 AM
  #48
Atomic's Avatar
Talked to jarret about the stock crank and stroker piston idea and it would work, but totally suck out of boost and not be that great in boost. Just doesnt work that well with the piston that far down in the cylinder.
I do have a stock 6.0 shortblock sitting outside torn down that I am thinking about making a 370 out of.
Yea going back with a 4" stroke crank.
DrX
Aug 11, 2015 07:25 AM
jmarkway
Jul 18, 2015 09:23 PM
goshawk23
Jun 21, 2006 06:35 PM
Nikon02
May 15, 2006 11:03 AM
Ryan23silverado
Feb 17, 2002 09:58 AM
