402 Teardown
Old Mar 24, 2013 | 01:17 PM
  #21
Atomic's Avatar
I have a gauge for that
0.0003 is the correct max spec, I thought wrong.
Old Mar 24, 2013 | 04:06 PM
  #22
oakley6575's Avatar
Damn that is pretty bad. You can't machine that much can you?
Old Mar 24, 2013 | 04:19 PM
  #23
Atomic's Avatar
Even if I could I wouldnt, this crank is cursed.
On another note...as a thought experiment, what would happen if I put in a stock 3.622 crank with my rods and pistons? "Stroker" pistons have a shorter pin height, but if you combine the shorter height with shorter stroke would you just have a really low compression 6.0? I worked the numbers and it would be around 8:1 SCR...
Wonder if it could take 35psi
Old Mar 24, 2013 | 04:26 PM
  #24
Chevy_King1500's Avatar
do it!!!
Old Mar 24, 2013 | 04:49 PM
  #25
Lowexpo's Avatar
heard the same about the Huntsville machine shop...
Old Mar 24, 2013 | 05:15 PM
  #26
supercharged680's Avatar
Normal was around 60ish, with 80+ at WOT....noticed the gauge sitting around 40cold, then dropping to 30 hot with barely any increase with rpm.
isn't 80+ at wot too much?
Old Mar 24, 2013 | 05:31 PM
  #27
Atomic's Avatar
It is on the high end but its fine. Just means the pump is working harder than it has to and there is some powerloss in that.
Heard what about hunstville machine shops?
Old Mar 24, 2013 | 05:41 PM
  #28
oakley6575's Avatar
30+ psi would be way to fun. Did you leave the pistons in the block or are you going to change the rings while your in there?
Old Mar 24, 2013 | 05:43 PM
  #29
Atomic's Avatar
Pistons are still in there hanging out...probably new rings when everything has to come out.
Old Mar 24, 2013 | 06:37 PM
  #30
Mangled03gmc's Avatar
Baltimore Whore
Damn you have had bad luck. Crank needs to go to the scrapper.
