05 ccsb help very very slow!!!!!!!!!!!!
Hello! Im new to the site and have been reading a good bit. i have an 05 crew cab with a lm7 cat less with magnaflow muffler and it is very slow, trying to decide what to do first. i was wondering what would be a good cam ,head,gears and stall for such a heavy truck? ive looked at the stage 2 5.3 head. whats different about those from the 706 beside larger valves. could i just get larger valves and heaver springs and a 3angle valve job and mill to the 706's how would that compare to stage 2 5.3's? the rpo says that the truck has a g80 but i have no posi. any ideas on what the problem could be with that? gears. i was thinking about 3.90 or 3.73. i dont see many people running 3.90. how do they compare to 3.73? i would like to put a shift kit in also to firm up my shifts any suggestions? im thinking about a yank 3000 stall converter will that be good for a dd? also wanted a factory joe gibbs supercharger set up of the trucks any idea where i can find a used one? thanks in advanced
Personally, I would supercharge the truck and finish all the bolt on mods with a good custom tune and then see what else you want to do. The setup most have gone with for excellent results are a Magnacharger mp112 or the new TVS 1900 and the GT2-3 camshaft.
Can't remember off hand if you have electric fans or not but if not...you can put those on your to do list as well but I believe 05 is when they started factory e-fans.
For my Crew Cab, I'm just wanted to get a Magnacharger to more humph towing and making the truck move a little bit easier but I will still retain my 3.23s for better mpg on the hwy since my truck is driven 90% of the time to work about 60-70mph.
Rick
drummer0415
11
Oct 24, 2015 08:16 PM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
whitelazer
Sep 22, 2015 09:38 PM
black00chev
16
Sep 15, 2015 05:40 AM
