05 ccsb help very very slow!!!!!!!!!!!!
Old Dec 5, 2009 | 09:39 AM
greenturtle05's Avatar
Default 05 ccsb help very very slow!!!!!!!!!!!!
Hello! Im new to the site and have been reading a good bit. i have an 05 crew cab with a lm7 cat less with magnaflow muffler and it is very slow, trying to decide what to do first. i was wondering what would be a good cam ,head,gears and stall for such a heavy truck? ive looked at the stage 2 5.3 head. whats different about those from the 706 beside larger valves. could i just get larger valves and heaver springs and a 3angle valve job and mill to the 706's how would that compare to stage 2 5.3's? the rpo says that the truck has a g80 but i have no posi. any ideas on what the problem could be with that? gears. i was thinking about 3.90 or 3.73. i dont see many people running 3.90. how do they compare to 3.73? i would like to put a shift kit in also to firm up my shifts any suggestions? im thinking about a yank 3000 stall converter will that be good for a dd? also wanted a factory joe gibbs supercharger set up of the trucks any idea where i can find a used one? thanks in advanced
Old Dec 5, 2009 | 09:59 AM
YenkoST's Avatar
Personally, I would supercharge the truck and finish all the bolt on mods with a good custom tune and then see what else you want to do. The setup most have gone with for excellent results are a Magnacharger mp112 or the new TVS 1900 and the GT2-3 camshaft.
Can't remember off hand if you have electric fans or not but if not...you can put those on your to do list as well but I believe 05 is when they started factory e-fans.
For my Crew Cab, I'm just wanted to get a Magnacharger to more humph towing and making the truck move a little bit easier but I will still retain my 3.23s for better mpg on the hwy since my truck is driven 90% of the time to work about 60-70mph.
Old Dec 5, 2009 | 11:07 AM
terravast4's Avatar
I agree. The magnacharger on an all stock set-up is a great kick in the ***. there are several 112's on sale here for cheap.
Old Dec 5, 2009 | 07:30 PM
Rick_Vor's Avatar
A used maggie would be ideal for your situation and cost about the same as the heads/cam/gears you are considering. Down the road, any of those additions will only make the Maggie even better.
Rick
Old Dec 5, 2009 | 08:36 PM
viciousknid's Avatar
Where's the Beef?
i'd start with cam, gears, tune. Cheaper than a supercharger. unless you can afford one, But then you'll need a transmission too.
Old Dec 5, 2009 | 08:41 PM
00ChevyScott's Avatar
Wearin' da big hat
TORQUE CONVERTER!
that should help.
Old Dec 5, 2009 | 10:38 PM
dlt76028's Avatar
i agree with getting a used magnacharger. they're around 2000-2500
Old Dec 5, 2009 | 10:39 PM
GMCtrk's Avatar
6.0 swap
Old Dec 12, 2009 | 11:12 PM
how much hp can i get from stage 2 5.3's and a cam?
Old Dec 13, 2009 | 12:49 PM
YenkoST's Avatar
Really depends on how big the cam is and if your heads are milled for more compression or less (for boost). But a good average is about 50-70hp with cam and heads depending on size, etc.
drummer0415
11
Oct 24, 2015 08:16 PM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
whitelazer
Sep 22, 2015 09:38 PM
black00chev
16
Sep 15, 2015 05:40 AM
