YaY another cam thread!
stipulations.
stock stall
stock heads
stock intake manifold.
less than .600 lift
thinking about the tsp 228 on a 112 to bring in the power in earlier to get past the stock stall speed.
im not apposed to running a vvt cam, just haven't found specs that tickled me yet.
thoughts?
stock stall
stock heads
less than .600 lift
thoughts?
stipulations.
stock stall
stock heads
less than .600 lift
thoughts?
stock stall
stock heads
less than .600 lift
thoughts?
If that's the case, then why sacrifice SO much driveability and low-speed torque for that last what - 10 or 15 RWHP?
I vote VVT, but unfortunately don't have an exact camshaft to recommend.
214/228 EPS vvt cam. It is the 2nd cam choice under the vvt cams.
228R is a great cam, but even with a 6.2L you will still want a 3200-3600 converter.
And yes normally you see split pattern cams with your engine and heads.
The new cam will increase my DCR which will also be nice.
OLD cam: (214/228 .559/.571) 114 LSA
NEW cam: (210/224 .556/.568) 114 LSA
I'll be selling my COMP version of this cam here in a week or two. I'm going a step down to get a little quieter idle...less RPMs, less lope.
