YaY another cam thread!
Old Nov 15, 2011 | 01:43 PM
Area47's Avatar
Default YaY another cam thread!
stipulations.
stock stall
stock heads
stock intake manifold.
less than .600 lift
thinking about the tsp 228 on a 112 to bring in the power in earlier to get past the stock stall speed.
im not apposed to running a vvt cam, just haven't found specs that tickled me yet.
thoughts?
Old Nov 15, 2011 | 02:05 PM
2007chevy5.3l's Avatar
Id go with something a bit smller if your gonna use the stock converter.
Old Nov 15, 2011 | 02:10 PM
Coban's Avatar
I agree, even with the 6.2. I don't typically see single pattern cams with the rectangular port heads either.
I like the cheater series cams.
Lloyd-TX's Avatar
Question
Originally Posted by Area47
stipulations.
stock stall
stock heads
less than .600 lift
thoughts?
Daily driver, correct?
If that's the case, then why sacrifice SO much driveability and low-speed torque for that last what - 10 or 15 RWHP?
I vote VVT, but unfortunately don't have an exact camshaft to recommend.
Old Nov 15, 2011 | 04:44 PM
Area47's Avatar
thats why i made this thread. to hear others idea's for the cam selections.
throw idea's at me. i haven't found a lot of options out there for ls3/lh9 based engines
Old Nov 15, 2011 | 06:30 PM
jrmchevyman's Avatar
214/228 EPS vvt cam. It is the 2nd cam choice under the vvt cams.
228R is a great cam, but even with a 6.2L you will still want a 3200-3600 converter.
And yes normally you see split pattern cams with your engine and heads.
Old Nov 15, 2011 | 07:03 PM
cam's Avatar
cam
214/228 EPS vvt cam
Old Nov 15, 2011 | 09:00 PM
Coban's Avatar
I'll be selling my COMP version of this cam here in a week or two. I'm going a step down to get a little quieter idle...less RPMs, less lope.
The new cam will increase my DCR which will also be nice.
OLD cam: (214/228 .559/.571) 114 LSA
NEW cam: (210/224 .556/.568) 114 LSA
Old Nov 15, 2011 | 09:36 PM
Area47's Avatar
i was actually lookin at your cam as a possible one. i have access to a dyno when ever there is free time to strap it down.
Old Nov 15, 2011 | 11:14 PM
pl4yboy's Avatar
Banned
EPS makes a 222/230 .597/.600 112 or 114 that would be perfect for you.
