Service Traction Control and Stabilitrak on WOT
Old 05-17-2016, 04:57 PM
Default Service Traction Control and Stabilitrak on WOT
Hi guys,
Every time I go WOT I get a Service Traction Control and Stabilitrak notification on the dash and both, the traction and ABS light stay on. It goes away when I shut the car off and start it again. When this happens, gear shifting goes out of whack and it feels like something is holding back the power (limp mode??)
Any ideas on what this could be?
Appreciated!
Old 05-17-2016, 06:20 PM
Wolftrk99's Avatar
It is a limp mode what year...(nvm i went back and got that lol!!) need to find out what the codes are that its throwing could be something in the tune, or with the throttle body, are you getting an engine light at all?? Basically limp mode locks you out of certain gears and maxes out line pressures!!!!
Old 05-18-2016, 12:00 AM
No engine light at all. But I'll try to scan for codes today and see what I get.
Old 05-18-2016, 09:08 AM
Wolftrk99's Avatar
If you can scan the abs module also...
Old 05-18-2016, 11:07 AM
Idryfly5's Avatar
What do you mean by "gear shifting goes out of wack"?
I had similar issues, trans would kick out of gear, door locks cycle, traction control lights, etc. Turned out to be the positive lead from starter to batter shorting out on the header and causing all kinds of problems.
Old 05-18-2016, 11:54 AM
11 Second Club
Mean Green z28's Avatar
while tuning, mine went into limp home mode when the tune hit the max grams/cyl limit in the tune. Ofcourse it was a tuning issue but def something to check since you're also running boost
Old 05-18-2016, 12:24 PM
madmann26's Avatar
Originally Posted by 20SS06
Hi guys,
Appreciated!
Mine does this when I loose traction. I would say it's normal based on what is happening.
Was traction control turned off in the tune? If not, once traction control is triggered, it can pull spark, fuel, etc.
Old 05-18-2016, 09:02 PM
I will definitely check that.
I say out of whack because it's almost as if it doesnt know whether to shift or not. It hesitates.
I have disabled traction control and ABS manually. I'm not sure if it's off in the tune.
Old 05-24-2016, 03:08 PM
So I changed the plugs and everything is back to normal. Who would have thought?
Black06GMC
05-03-2016 12:11 AM
Chevyss909
05-01-2016 06:15 PM
Lowexpo
04-28-2016 11:19 AM
GM1697
04-21-2016 09:06 PM
hodge9386
04-20-2016 06:48 AM
Quick Reply: Service Traction Control and Stabilitrak on WOT
