Timing chain and tensioner help
Old Apr 27, 2016 | 01:57 PM
Lowexpo's Avatar
Default Timing chain and tensioner help
Hello all, I'm about to do DOD delete on my 2007 5.3 Tahoe. I have almost everything but need input. I'm replacing the timing set (170,000miles plus I'm replacing oil pump). Use stock LS2 set and block style tensioner? Saw Blckgmc suggest a tensioner from trick flow. Do I need that kit because I don't have bolt holes in block or just need stock tensioner? Thanks in advance
Old Apr 27, 2016 | 05:02 PM
Wolftrk99's Avatar
Just get the ls2 style block dampener if youbhave dod your engine has the holes for the tensioner there already... Part number is 12588670..... if youre deleting the dod get the truck valley cover 12598832 from a 4.8 or 6.0 truck without afm and save about $90 over the ls3 style....
Old Apr 28, 2016 | 04:06 AM
Lowexpo's Avatar
Thanks Wolftrk99.
Old Apr 28, 2016 | 07:02 AM
Wolftrk99's Avatar
Not a problem, make sure yiu check your cam bearings while it apart....
Old Apr 28, 2016 | 11:10 AM
tim wellington's Avatar
Default cam tensioner
trick flow one bolts to cam plate .no holes in block needed that what run
Old Apr 28, 2016 | 11:19 AM
Wolftrk99's Avatar
Gen iv blocjs with dod use chain tensioner and already have the holes in the block for it.... The trick flow set is for gen 3 engines that dont have the tapped holes already
Time2Kill
Dec 29, 2020 11:36 AM
Mr. Chainsaw
Apr 16, 2016 07:51 PM
sharpshooter
Apr 5, 2016 08:13 PM
07NBSChevy
Apr 2, 2016 01:20 AM
SebringSilverZ
Mar 28, 2016 07:48 PM
