my rebuild
#101
Thats what im thinking myself. Imma slap a stock tb back on it to see. Yet the thing is it never did it with the old motor. Put this motor in it started misfiring.
#102
the TB swap would definitely be an easy test to do!what happens with the misfire? im just curious on what made you notice it in the first place!
#104
did you get a chance to try the TB today?
just thinking about it today, I don't think it'd be a knock sensor issue cause that'd probly be a "load" issue and have a wider % like say 40-55% or something
I don't think cam sensor causing a injector miss cause again...thatd be rpm related I think not just %47 throttle
its definitely not a mechanical miss cause you definitely eliminated any causes of that and again its to specific to that %
so that leaves a TPS sensor, MAF sensor or MAP sensor issue or even a TB blade sticking or something
#106
I haven't done anything with VE tables other then see a picture of it on EFI Live but if it was at X rpm, wouldn't it do it every gear in a different spot? and not to mention at %47 throttle your rpms are probly climbing fairly quick in that thing!
#109
Don't do it Niff ! You've done too much good stuff to her to burn it down now !
You say you did put the stock truck TB back on ?
I also read you have her running on the old tune? Did it miss on this tune or after you retuned/tweaked for different injectors ?
#110
I had the same issues a bit. My throttle would close to 50% after 4000RPM or some dumb **** I cant recall. Took my tuner and I quite some time and screwing around to get it sorted out and now I have NO rev limiter ( has proven interesting lemme tell ya )
Gen IV swaps are painful, VERY painful. Keniff hang in there man someone knows ( Post up over at HP forum, one of the tuners there fixed mine somehow although Ihave no idea what he did )
