my rebuild
Old Dec 10, 2013 | 08:23 PM
  #111
iamkeniff's Avatar
i havent tried a stock tb yet. although yes it is on the old cam tune but no it never misfired at all. no issues with it. all i did was put a converter in it this time. i swapped oem injectors back in and the 1 i thought was the miss wasnt it. i put it on #1 and the misfire is still on #2.
area47 changed all kinds of crap. along with the MAP/MAF tables. the truck is driving around right now with the DTC misfire table maxed out so the truck doesnt freak out. it drives around with a light misfire when i do that but it'll hold that misfire at 47% for as long as i hold it at 47% no matter what gear.
Old Dec 12, 2013 | 10:26 AM
  #112
cam's Avatar
cam
Misfire eh? Hmm sounds like fun. Well to quote the old broken record I think id start old school on this and add a bunch of grounds to begin with. Only makes a good thing better even if you dont need them. Plus 99% of the time when theres a wiring issue ( not saying you have one ) but when there is a wiring issue its almost always a ground problem.
As for what to sort out in the tune? Have you logged the misfire and posted up the file over at HP?
Old Dec 12, 2013 | 12:59 PM
  #113
Area47's Avatar
cam has a point about the grounds. never thought of that.
Old Dec 12, 2013 | 10:41 PM
  #114
iamkeniff's Avatar
Area47 has seen the scans. Its crazy how itll misfire on #2
I can add a couple grounds but all of the oem grounds are on tight.
Old Dec 13, 2013 | 07:03 PM
  #115
02Reaper's Avatar
Have you checked the wiring where you extended your harness for your coils? Could be a cold soldier joint or something in the wiring.
Old Dec 14, 2013 | 08:27 AM
  #116
iamkeniff's Avatar
Its all oem harnesses. The coils are back in factory location.
Br7 plugs
Bosch wires
Oem coil harnesses
Oem coils
Old Dec 14, 2013 | 01:21 PM
  #117
02Reaper's Avatar
Are those BR7 spark plugs the recessed head ones?
Old Dec 14, 2013 | 02:04 PM
  #118
iamkeniff's Avatar
Idk they are non projected. It misfired on the tr55s wih 059 gap these br7s wth 035 gap
I wonder if i need to go back to a TR6 like i use to run gapped at 040
Old Dec 14, 2013 | 04:37 PM
  #119
02Reaper's Avatar
If you ran the tr55s and it done the same thing, then I doubt the tr6's would help either. With your current setup, I would stay with either the tr55 or the tr6 though...Are you tuning with hptuners or efilive?
Old Dec 14, 2013 | 05:39 PM
  #120
iamkeniff's Avatar
I have hptuner but the person looking at it tuesday before i blow it up has efilive.
Ill probably put a set of TR6s in it like i use to run. Im not running 11:1cr like i wanted but its all good.
