2008 Silverado projector retrofit...
Old Dec 24, 2015 | 05:01 PM
  #31
08Silveradojp's Avatar
Originally Posted by Tig
I can completely understand.
I cant believe how much material is removed, there's almost no bowl left.
That's what someone told me. It shouldn't sit too close to the lens but if that's how it fits, its not really a problem. Though I'm going to try and have them further back.
Yeah hopefully today I can have one at least set in. But the hole saw deal I used was a lot cleaner and easier .
Old Dec 24, 2015 | 06:09 PM
  #32
Tig's Avatar
Tig
Good luck, hopefully everything works out.
The one tool everyone told me to get was a Dremel.
Old Dec 24, 2015 | 06:13 PM
  #33
We'll find out tonight
Old Dec 24, 2015 | 06:38 PM
  #34
I found the second quad setup it actually looks the same almost but more information hope this helps!
LML Quad projector headlight retrofit - Chevy and GMC Duramax Diesel Forum
Old Dec 24, 2015 | 06:47 PM
  #35
Tig's Avatar
Tig
Good Luck
Old Dec 24, 2015 | 08:22 PM
  #36
Good Luck
I got some pics for some reason it only uploads one pic . But it measures 3.871 from the front of the projector shroud to the back which is about the same from back threads to the clip positions. But we'll see when I cut the whole bigger
Old Dec 24, 2015 | 09:18 PM
  #37
Tig's Avatar
Tig
I didn't notice this, until now.
Another good thread to see what's going on back there.
Very cool.
Do you have a lot of room behind whole headlight assembly?
I have a very limited amount of space, two metal frames right behind each light, grrrr.
Old Dec 24, 2015 | 10:39 PM
  #38
Very cool.
No I don't have very much space behind headlight assembly I have Made it that far but I can safely say with a little more trimming on shroud that the projector will sit with the lens being about a 1-1/4 away from the lens the only thing is like I said I cut the hole in the lens really big and now I need a big washer to support the nut behind it I am also not sure if it will function the same...here's the hold before and I made it significantly bigger
Old Dec 25, 2015 | 06:51 AM
  #39
Tig's Avatar
Tig
You cut a hole in the lens? Why in the lens?
I thought the only cutting necessary was in the bowl/reflector?
Old Dec 25, 2015 | 10:45 AM
  #40
I'm sorry no not the lens stupid me must of got excited I meant the bowl lol be I didn't want to cut the bowl out of the reflector housing. If I had have to do all that I'm going to put highs and lows. But when I do my driver side light I'll post pics of everything. Is there anything you want pics of?
