what cubic inch motor is the 5.3?
Old Mar 27, 2006 | 02:04 PM
Default what cubic inch motor is the 5.3?
dumb question i know. but just curious. thanks!
Old Mar 27, 2006 | 02:14 PM
dewmanshu's Avatar
Moderately Differentiated
323 or about 60.9 per liter
Old Mar 27, 2006 | 02:20 PM
323?
never heard of such. but wow thanks for the help, cuz i had no idea!!
Old Mar 27, 2006 | 02:30 PM
dewmanshu's Avatar
ahhh 323 or 325 just depends who you ask I guess. LOL I believe the 4.8 is 294 on one manufacturers website and a 295 on another. Then the 6.0 is 363 on one and 364 on another. You divide those out and the calculation makes no sense. anywhere from 60.1 to 61.25 cubic inches a liter.
Old Mar 27, 2006 | 03:48 PM
83 Chevy's Avatar
Chevy calls it a 327. The bore is 96.0 mm and the stroke is 92.0 mm. The volume of 8 cylinders is 5,327,336.89 cubic millimeters, or 5,327.34 cubic centimeters. The volume in cubic inches is 325.09.
Just FYI, there are 25.4^3 (to the third power) cubic millimeters in a cubic inch.
I teach math
Mike
Old Mar 27, 2006 | 03:57 PM
BlownChevy's Avatar
blownerator
25 Year Member
1+1=3?
CHAGO's Avatar
yea, Ive been told on many occasions its a 325 and the 6.0 a 364
Old Mar 27, 2006 | 04:11 PM
83 Chevy's Avatar
The 6.0 has a stated bore of 4.00 inches and a stroke of 3.62 inches. If the 3.62 stroke is exact, the 6.0 liter has 363.92 cubic inches of displacement.
If the 3.62 is actually rounded down from 3.625 (3-5/8"), then it has 364.42 cubic inches of displacement.
Mike
Old Mar 27, 2006 | 04:26 PM
ranwalk's Avatar
Yes, a 5.3 is a 325. That is straight from GM's SI site for dealers.
GM has never called the 5.3 a 327
Document ID# 1489513
2005 Chevrolet Tahoe - 2WD
Engine Mechanical Specifications (LM7 VIN T)
Application
Specification
Metric
English
General
Engine Type
V8
Displacement
5.3L
325 CID
RPO
LM7
VIN
T
Bore
96.0-96.018 mm
3.779-3.78 in
Stroke
92.0 mm
3.622 in
Compression Ratio
9.5:1
Firing Order
1-8-7-2-6-5-4-3
Spark Plug Gap
1.02 mm
0.04 in
Block
Camshaft Bearing Bore 1 and 5 Diameter
59.62-59.67 mm
2.347-2.349 in
Camshaft Bearing Bore 2 and 4 Diameter
59.12-59.17 mm
2.327-2.329 in
Camshaft Bearing Bore 3 Diameter
58.62-58.67 mm
2.307-2.309 in
Crankshaft Main Bearing Bore Diameter
69.871-69.889 mm
2.75-2.751 in
Crankshaft Main Bearing Bore Out-of-Round
0.006 mm
0.0002 in
Cylinder Bore Diameter
96.0-96.018 mm
3.779-3.78 in
Cylinder Head Deck Height - Measuring from the Centerline of Crankshaft to the Deck Face
234.57-234.82 mm
9.235-9.245 in
Cylinder Head Deck Surface Flatness - Measured within a 152.4 mm (6.0 in) Area
0.11 mm
0.004 in
Cylinder Head Deck Surface Flatness - Measuring the Overall Length of the Block Deck
0.22 mm
0.008 in
Valve Lifter Bore Diameter
21.417-21.443 mm
0.843-0.844 in
Camshaft
Camshaft End Play
0.025-0.305 mm
0.001-0.012 in
Camshaft Journal Diameter
54.99-55.04 mm
2.164-2.166 in
Camshaft Journal Out-of-Round
0.025 mm
0.001 in
Camshaft Lobe Lift - Exhaust
6.96 mm
0.274 in
Camshaft Lobe Lift - Intake
6.82 mm
0.268 in
Camshaft Runout - Measured at the Intermediate Journals
0.05 mm
0.002 in
Connecting Rod
Connecting Rod Bearing Clearance - Production
0.023-0.065 mm
0.0009-0.0025 in
Connecting Rod Bearing Clearance - Service
0.023-0.076 mm
0.0009-0.003 in
Connecting Rod Bore Diameter - Bearing End
56.505-56.525 mm
2.224-2.225 in
Connecting Rod Bore Out-of-Round - Bearing End - Production
0.004-0.008 mm
0.00015-0.0003 in
Connecting Rod Bore Out-of-Round - Bearing End - Service
0.004-0.008 mm
0.00015-0.0003 in
Connecting Rod Side Clearance
0.11-0.51 mm
0.00433-0.02 in
Crankshaft
Connecting Rod Journal Diameter - Production
53.318-53.338 mm
2.0991-2.0999 in
Connecting Rod Journal Diameter - Service
53.308 mm
2.0987 in
Connecting Rod Journal Out-of-Round - Production
0.005 mm
0.0002 in
Connecting Rod Journal Out-of-Round - Service
0.01 mm
0.0004 in
Connecting Rod Journal Taper - Maximum for 1/2 of Journal Length - Production
0.005 mm
0.0002 in
Connecting Rod Journal Taper - Maximum for 1/2 of Journal Length - Service
0.02 mm
0.00078 in
Crankshaft End Play
0.04-0.2 mm
0.0015-0.0078 in
Crankshaft Main Bearing Clearance - Production
0.02-0.052 mm
0.0008-0.0021 in
Crankshaft Main Bearing Clearance - Service
0.02-0.065 mm
0.0008-0.0025 in
Crankshaft Main Journal Diameter - Production
64.992-65.008 mm
2.558-2.559 in
Crankshaft Main Journal Diameter - Service
64.992 mm
2.558 in
Crankshaft Main Journal Out-of-Round - Production
0.003 mm
0.000118 in
Crankshaft Main Journal Out-of-Round - Service
0.008 mm
0.0003 in
Crankshaft Main Journal Taper - Production
0.01 mm
0.0004 in
Crankshaft Main Journal Taper - Service
0.02 mm
0.00078 in
Crankshaft Rear Flange Runout
0.05 mm
0.002 in
Crankshaft Reluctor Ring Runout - Measured 1.0 mm (0.04 in) Below Tooth Diameter
0.7 mm
0.028 in
Crankshaft Thrust Surface - Production
26.14-26.22 mm
1.029-1.0315 in
Crankshaft Thrust Surface - Service
26.22 mm
1.0315 in
Crankshaft Thrust Surface Runout
0.025 mm
0.001 in
Cylinder Head
Cylinder Head Height/Thickness - Measured from the Cylinder Head Deck to the Valve Rocker Arm Cover Seal Surface
120.2 mm
4.732 in
Surface Flatness - Block Deck - Measured within a 152.4 mm (6.0 in) Area
0.08 mm
0.003 in
Surface Flatness - Block Deck - Measuring the Overall Length of the Cylinder Head
0.1 mm
0.004 in
Surface Flatness - Exhaust Manifold Deck
0.13 mm
0.005 in
Surface Flatness - Intake Manifold Deck
0.08 mm
0.0031 in
Valve Guide Installed Height - Measured from the Spring Seat Surface to the Top of the Guide
17.32 mm
0.682 in
Intake Manifold
Surface Flatness - Measured at Gasket Sealing Surfaces and Measured within a 200 mm (7.87 in) Area that Includes 2 Runner Port Openings
0.3 mm
0.118 in
Lubrication System
Oil Capacity - with Filter
5.68 liters
6.0 quarts
Oil Capacity - without Filter
4.73 liters
5.0 quarts
Oil Pressure - Minimum - Hot
41 kPa at 1,000 engine RPM
124 kPa at 2,000 engine RPM
165 kPa at 4,000 engine RPM
6 psig at 1,000 engine RPM
18 psig at 2,000 engine RPM
24 psig at 4,000 engine RPM
Oil Pan
Front Cover Alignment - at Oil Pan Surface
0.0-0.5 mm
0.0-0.02 in
Rear Housing Alignment - at Oil Pan Surface
0.0-0.5 mm
0.0-0.02 in
Oil Pan Alignment - to Rear of Engine Block at Transmission Bell Housing Mounting Surface
0.0-0.1 mm
0.0-0.004 in
Piston Rings
Piston Ring End Gap - First Compression Ring - Measured in Cylinder Bore - Production
0.23-0.44 mm
0.009-0.017 in
Piston Ring End Gap - First Compression Ring - Measured in Cylinder Bore - Service
0.23-0.5 mm
0.009-0.0196 in
Piston Ring End Gap - Second Compression Ring - Measured in Cylinder Bore - Production
0.44-0.7 mm
0.017-0.027 in
Piston Ring End Gap - Second Compression Ring - Measured in Cylinder Bore - Service
0.44-0.76 mm
0.0173-0.03 in
Piston Ring End Gap - Oil Control Ring - Measured in Cylinder Bore - Production
0.18-0.75 mm
0.007-0.029 in
Piston Ring End Gap - Oil Control Ring - Measured in Cylinder Bore - Service
0.18-0.81 mm
0.007-0.032 in
Piston Ring to Groove Clearance - First Compression Ring - Production
0.04-0.085 mm
0.00157-0.00335 in
Piston Ring to Groove Clearance - First Compression Ring - Service
0.04-0.085 mm
0.00157-0.00335 in
Piston Ring to Groove Clearance - Second Compression Ring - Production
0.04-0.078 mm
0.00157-0.0031 in
Piston Ring to Groove Clearance - Second Compression Ring - Service
0.04-0.078 mm
0.00157-0.0031 in
Piston Ring to Groove Clearance - Oil Control Ring - Production
0.012-0.2 mm
0.0005-0.0078 in
Piston Ring to Groove Clearance - Oil Control Ring - Service
0.012-0.2 mm
0.0005-0.0078 in
Pistons and Pins
Pin - Piston Pin Clearance to Piston Pin Bore - Production
0.002-0.01 mm
0.00008-0.0004 in
Pin - Piston Pin Clearance to Piston Pin Bore - Service
0.002-0.015 mm
0.00008-0.0006 in
Pin - Piston Pin Diameter
23.952-23.955 mm
0.943-0.943 in
Pin - Piston Pin Fit in Connecting Rod Bore - Production
0.007-0.02 mm
0.00027-0.00078 in
Pin - Piston Pin Fit in Connecting Rod Bore - Service
0.007-0.022 mm
0.00027-0.00086 in
Piston - Piston Diameter - Measured Over Skirt Coating
96.002-96.036 mm
3.779-3.78 in
Piston - Piston to Bore Clearance - Production
-0.036 to +0.016 mm
-0.0014 to +0.0006 in
Piston - Piston to Bore Clearance - Service Limit with Skirt Coating Worn Off
0.071 mm
0.0028 in
Valve System
Valves - Valve Face Angle
45 degrees
Valves - Valve Face Width
1.25 mm
0.05 in
Valves - Valve Lash
Net Lash - No Adjustment
Valves - Valve Lift - Exhaust
11.82 mm
0.465 in
Valves - Valve Lift - Intake
11.58 mm
0.456 in
Valves - Valve Seat Angle
46 degrees
Valves - Valve Seat Runout
0.05 mm
0.002 in
Valves - Valve Seat Width - Exhaust
1.78 mm
0.07 in
Valves - Seat Width - Intake
1.02 mm
0.04 in
Valves - Valve Stem Diameter - Production
7.955-7.976 mm
0.313-0.314 in
Valves - Valve Stem Diameter - Service
7.95 mm
0.313 in
Valves - Valve Stem-to-Guide Clearance - Production - Intake
0.025-0.066 mm
0.001-0.0026 in
Valves - Valve Stem-to-Guide Clearance - Service - Intake
0.093 mm
0.0037 in
Valves - Valve Stem-to-Guide Clearance - Production - Exhaust
0.025-0.066 mm
0.001-0.0026 in
Valves - Valve Stem-to-Guide Clearance - Service - Exhaust
0.093 mm
0.0037 in
Rocker Arms - Valve Rocker Arm Ratio
1.70:1
Valve Springs - Valve Spring Free Length
52.9 mm
2.08 in
Valve Springs - Valve Spring Installed Height
45.75 mm
1.8 in
Valve Springs - Valve Spring Load - Closed
340 N at 45.75 mm
76 lb at 1.8 in
Valve Springs - Valve Spring Load - Open
980 N at 33.55 mm
220 lb at 1.32 in
Old Mar 27, 2006 | 04:35 PM
StrokerAce03's Avatar
Wow, that explains it all Ranwalk. I like how it has in. and mm. I've always heard 325 cu. in. and never 323.
