Things to do when an engine is out
Old 09-26-2018, 04:00 PM
wretched73's Avatar
Originally Posted by JonToski187
Also what is this "cowl" you guys speak of I only know it in reference of crotch rockets because I use to have one.
It's between your windshield and engine bay. Big piece of plastic covers it, allows air in for HVAC
Old 09-26-2018, 04:02 PM
JonToski187's Avatar
Ok like where the windshield wipers kinda are?
Old 09-26-2018, 05:03 PM
arthursc2's Avatar
Received 1,435 Likes on 1,062 Posts
Yes
-Remove wipers
-Remove washer line connect
-Remove 5-6 clips from cowl to firewall
-Remove side covers and small torx under them (x2)
-REMOVE THE CENTER BARB
-It should lift off then. Be careful, dont force it.
Old 09-26-2018, 05:40 PM
100% Redneck
RedXray's Avatar
Received 1,331 Likes on 793 Posts
Some very good advice in this thread. How far you go depends on your goals and skill level. I cleaned everything and every place I could get at. Painted frame rails replace all the plastic loom. All the ABS wire loom just crumbled to the touch and replaced that too. I even polished the paint on the firewall as I knew I'd (hopefully) never have another chance...
did I go to far
Old 09-26-2018, 05:45 PM
Originally Posted by RedXray
Some very good advice in this thread. How far you go depends on your goals and skill level. I cleaned everything and every place I could get at. Painted frame rails replace all the plastic loom. All the ABS wire loom just crumbled to the touch and replaced that too. I even polished the paint on the firewall as I knew I'd (hopefully) never have another chance...<br /><br />did I go to far <br /><br /><img src="https://i.imgur.com/TVZ7Hgq.jpg"/>
Whao that is pretty far. I left my AC and power steering in. I don't have a fancy place or tools to do things like I see some guys on here do. It's a normal house garage and a craftsman tool box. Most I've ever done to a truck is heads and cam.
I made a build thread here https://www.performancetrucks.net/fo...6/#post5448558
Raughammer
11
12-29-2020 09:28 AM
pewter00
09-14-2015 09:17 PM
Ferocity02
03-03-2015 04:19 PM
Fastcount03
11-04-2012 10:47 AM
Sport Side
06-22-2006 08:48 PM
Quick Reply: Things to do when an engine is out
