stock 1/4 times
Old Dec 16, 2007 | 05:48 AM
Parke10's Avatar
Default stock 1/4 times
yes another stock 1/4 time question, i found alot but nothing for this one..
my buddy is looking at a 2005 CCSB 2wd 5.3 ,whats the stock times for that?
thanks in advance
Old Dec 16, 2007 | 10:42 AM
MonteCarlo31's Avatar
I'd say low 16s. I ran a 16.8 w/ 33x11.5 BFG MTs and 3.42 gears w/ a good tune. Keep in mind these tires are 1.5" taller then a stock tire (measured) and are about 12 lbs a tire heavier w/ more rolling resistance.
Old Dec 16, 2007 | 02:17 PM
viciousknid's Avatar
Where's the Beef?
I'd say low 16's for an ECSB. mid 17's for a CCSB. Your tires are giving you more rolling resistance but your tune is compensating and then some.
Old Dec 17, 2007 | 05:50 AM
True, I was thinking with 2wd he's probably 200 to 300 lbs lighter anyway and has shorter tires so that would be a huge help. I looked up a old truck trends and he should be at 16.1 @ 87 mph w/ 3.23 axle ratio.
Old Dec 17, 2007 | 06:05 AM
beastmode's Avatar
Import Moderator
1.5 seconds difference cause its a crewcab instead of an extended cab
the tune doesnt compensate for the tires, it just adjusts the speedo and stuff. gearing compensates for tire size. granted his tune was adding more power but not enough to compensate for having that size tire on. one of hte best mods for the money if you have 3.23/3.42s and you plan to run 33" tires all the time is to swap to 4.10/4.30s.
id say you should do a mid 16
Old Dec 18, 2007 | 02:12 AM
RickLowpez's Avatar
my buddys 04 ccsb 2wd runs hella good im pretty sure itll run low 16s if not high 15s stock
Old Dec 20, 2007 | 05:19 AM
Where's the Beef?
I was just guestimating based on some info i seen on a ECSB 5.3 hybrid doing low 16"s I figured roughly a second difference for the CC. Whats the difference between an ECSB and CCSB usually?
Old Dec 20, 2007 | 09:41 AM
Snacktime's Avatar
Made in South Korea
Should only be a few tenths
Choda
Jan 22, 2026 02:03 PM
ARC
57
Feb 21, 2022 10:54 AM
thunder550
Oct 8, 2015 04:53 PM
fastjweb
Aug 15, 2015 10:47 AM
fcompean
Jul 15, 2015 09:55 PM
