stock 1/4 times
yes another stock 1/4 time question, i found alot but nothing for this one..
my buddy is looking at a 2005 CCSB 2wd 5.3 ,whats the stock times for that?
thanks in advance
thanks in advance
I'd say low 16s. I ran a 16.8 w/ 33x11.5 BFG MTs and 3.42 gears w/ a good tune. Keep in mind these tires are 1.5" taller then a stock tire (measured) and are about 12 lbs a tire heavier w/ more rolling resistance.
I'd say low 16's for an ECSB. mid 17's for a CCSB. Your tires are giving you more rolling resistance but your tune is compensating and then some.
True, I was thinking with 2wd he's probably 200 to 300 lbs lighter anyway and has shorter tires so that would be a huge help. I looked up a old truck trends and he should be at 16.1 @ 87 mph w/ 3.23 axle ratio.
the tune doesnt compensate for the tires, it just adjusts the speedo and stuff. gearing compensates for tire size. granted his tune was adding more power but not enough to compensate for having that size tire on. one of hte best mods for the money if you have 3.23/3.42s and you plan to run 33" tires all the time is to swap to 4.10/4.30s.
id say you should do a mid 16
I was just guestimating based on some info i seen on a ECSB 5.3 hybrid doing low 16"s I figured roughly a second difference for the CC. Whats the difference between an ECSB and CCSB usually?
Choda
Jan 22, 2026 02:03 PM
ARC
57
Feb 21, 2022 10:54 AM
