No start after engine/transmission swap...
Old Sep 19, 2016 | 04:42 PM
  #21
10 Second Club
Originally Posted by MrHorsepowerLSx
You could swap the engine/trans back into the other truck and see if it starts, then start over
That truck is long gone, it was totalled last year. It still ran and moved under its own power despite being all smashed and bent up.
Old Sep 19, 2016 | 05:35 PM
  #22
Wolftrk99's Avatar
Vats doesnt kill spark, and with a vats issue it should technically start and run for two seconds and then shut off
Old Sep 20, 2016 | 12:33 PM
  #23
10 Second Club
I found the problem... now I need to find one of these pins and fix it.
Attached Thumbnails No start after engine/transmission swap...-img_20160920_131517871.jpg   No start after engine/transmission swap...-img_20160920_132643426.jpg
Old Sep 20, 2016 | 01:42 PM
  #24
10 Second Club
I patched it together and got it fixed. It starts, runs a few seconds, shuts off. Then I get a flashing security light. I believe now it is a VATS issue and needs to be reset. I will go through the process tomorrow and hope that this is the end of all the BS.
Old Sep 20, 2016 | 03:35 PM
  #25
MrHorsepowerLSx's Avatar
11 Second Club
Good to hear progress is being made
Old Sep 20, 2016 | 09:56 PM
  #26
Wolftrk99's Avatar
....Called it!!! Knew it had something to do with crank sensor, glad you are making progress!!!
Old Sep 21, 2016 | 05:55 PM
  #27
10 Second Club
So I go over there today to do the VATs relearn... turn the key, no security light. F it, I start it - fires right up and settled in on a decent idle. I am not going to complain. Once running, had a massive transmission fluid leak. My fault, forgot to tighten a fitting on the line. Quick fix, not a major issue.
I am going to try to get all of the fluids topped off tomorrow. Then I need to finish the rear sway bar install. And put my trailer hitch back on. Hoping to put 100 miles on it Saturday and feel it out.
Old Sep 21, 2016 | 07:21 PM
  #28
Wolftrk99's Avatar
May have primed the fuel pump last time, and in trying to do other stuff done the vats relearn may have been done on accident...
mhorn0817
Nov 6, 2016 12:14 PM
silvy13
Jul 17, 2016 05:16 PM
TXjeepTJ
Jul 7, 2016 08:24 PM
slicpartna
Jul 4, 2016 10:17 AM
V8Rumble
Jun 28, 2016 12:21 PM
