Ls1 fans?
Old Apr 27, 2011 | 05:33 PM
david0982's Avatar
Default Ls1 fans?
Are Ls1 fans direct bolt on on a 2003 RCSB or would i have to modify them. 28" radiator.
Old Apr 27, 2011 | 07:26 PM
andrew383's Avatar
traveling mod
They fit the smaller radiator the best yes..I think you have to make a small bracket or 2,nothin major..
Old Apr 27, 2011 | 07:38 PM
Nuclear Endless's Avatar
Yes, the worst that could happen is theyre a tad bit small, might have to use some good zip ties or a metal bracket to hold it over the rad, whatever way you can rig it up
Old Apr 28, 2011 | 08:01 AM
david0982's Avatar
Ok so the 05 fans are probably the way to go?
Old Apr 29, 2011 | 07:29 PM
SnakeOiler's Avatar
For a direct fit yes, but you would have to get the larger radiator
Old May 1, 2011 | 01:11 PM
marovetsm's Avatar
I just made 2 little brackets with strap metal. I chose LS1 fans cuz I got them super cheap and I didnt have to get new radiator. I also built my own harness and they work flawlessly.
Old May 1, 2011 | 02:09 PM
rel3rd's Avatar
11 Second Club
Same here. The LS1 fans fit the 28" radiator like stock...almost.
Like shown above, use some steel brackets as the zip ties, even ones made for tranny coolers (like I originally used) WILL loosen up and allow the fan to move around.
Old May 1, 2011 | 05:28 PM
fastnblu's Avatar
Read SnakeOiler's quote. david0982, you're confusing things a bit as they're 2 different questions. If ya wanna stick w/. your stock rad, get LS1 fans. '05 -up use 34" rad. Some like the LS1 fans cause they're cheap to get, & don't req. a rad. upgrade.
Nice clean install, looks good.
Old May 1, 2011 | 06:26 PM
what all was part of your homemade harness?
CD82
Oct 23, 2015 07:32 AM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
Dawas
Sep 20, 2015 12:00 PM
FormulaZR
Sep 14, 2015 05:23 PM
