34inch rad , electric fan only, shroud???
Old Sep 22, 2011 | 08:27 PM
getchusum99's Avatar
Default 34inch rad , electric fan only, shroud???
do the ymake a stock shroud to go with your stock clutch fan for use with th 34inch radiator???
Old Sep 22, 2011 | 08:29 PM
Atomic's Avatar
I have a gauge for that
maybe a 2000-04 2500hd...
Old Sep 22, 2011 | 09:57 PM
andrew383's Avatar
traveling mod
Yes..Look for one in a tahoe or burb
Old Sep 24, 2011 | 10:50 AM
what year model tahoe or suburban? and did the 99-02 2500hd's with the 6.0's have the 34inch rad?
Old Sep 24, 2011 | 11:16 AM
budhayes3's Avatar
PT's Slowest Truck
Yes they did, you should be able to use the shroud from an HD w/o efans
Old Sep 24, 2011 | 11:34 AM
andrew383's Avatar
traveling mod
Mine is an 03 and it has it so id start with the 03-04..I think the pre 03's had the 28" radiator but im not 100% sure..
Old Sep 24, 2011 | 11:45 AM
thanks guys, i still plan on putting my 05 efans and ASP underdrive pulleys on , but goota get my truck back together soon, so ima wait to do the pcm upgrade,wiring harness and new belts that all go with the new fans and pulley, and just go with the 34inch rad and clutch fan for now.
Old Sep 24, 2011 | 11:56 AM
1Bear's Avatar
There were plenty of trucks and SUV’s that were factory equipped with the 34” radiator and a clutch fan. You can look for the components from a ’01 GMC C³, ‘01 thru ‘04 Yukon Denali, ‘02 thru ‘04 Sierra Denali, ’02 thru ’04 Cadillac Escalade, ’03 & ’04 Silverado SS, as all of these were ½ tons with 6.0L. There may be other fitments as well, but just with this list of possible donors, I believe you have plenty of options.
Old Sep 24, 2011 | 03:58 PM
thanks 1Bear, hopefully i can find one in a salvage yard somewhere
SS94S10
Jan 3, 2019 01:57 PM
CD82
Oct 23, 2015 07:32 AM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
