Would this E-fan work
Old Feb 22, 2004 | 12:59 AM
TwoFast's Avatar
Default Would this E-fan work
My bro works at O'Reilly's Auto parts and told me today that he could get me a great deal on an electric fan for my truck ($50). The fan has a diameter of 16" Fans rpm is 2000rpm@13.5VDC Airflow rate is 2000 and it draws 11 amps. Its made by Bullett its called a Pro-Air Electric Fan (straight blade)
Will this give me enough cooling power, I figure it will because it would be a larger diameter than the stock fan. Also will loosing 11 amps dim my lights or put strain on my alternator, or will it be just fine?
Old Feb 22, 2004 | 02:17 AM
Yelo's Avatar
The stock mech-fan pulls close to 5000 CFM.....as long as you don't do any heavy towing you should be fine with the single electric fan but with the a/c on towing a trailer you WILL overheat
Old Feb 22, 2004 | 09:14 AM
As hot as it gets in the summer where you're at, I wouldn't think it'd be enough. You generally get what you pay for. I would stick with LS1 or Flex-a-lite fans.
Old Feb 22, 2004 | 09:54 AM
How many amps do the LS1 fans draw? What about the CFM for it?
Old Feb 22, 2004 | 09:56 AM
Texas Terminator's Avatar
11 Second Club
no way. it would never keep up with the heat.
Old Feb 22, 2004 | 11:15 AM
The 16" won't do it, however two 14" fans will be plenty. Fits nicely too!
Old Feb 22, 2004 | 05:55 PM
TwoFast's Avatar
What about duel 12" fans would that work. Look on ebay under Electric Fans an it should have a couple listings of 12" duel electric fans for like $69. let me know because I'm wanting them real bad so I can install a better intake I designed for better air flow.
Old Feb 22, 2004 | 11:57 PM
TwoFast's Avatar
Can someone look at these fans and let me know if they will work? thanks
Stainless Works
Apr 10, 2016 04:34 PM
thunder550
Oct 8, 2015 04:53 PM
Stainless Works
Aug 4, 2015 12:56 PM
atxlt
Jul 20, 2015 11:06 PM
Nimoryan
Jul 5, 2015 03:50 PM
