Total Newb Question but any help is appreciated
Old Mar 26, 2011 | 09:55 PM
Default Total Newb Question but any help is appreciated
So im attempting changing the water pump on my GMC5.3 and i got this info from Chiltons online,
"Install or connect the following:
Water pump. Install the water pump bolts. Tighten the water pump bolts first pass to 11 ft. lbs. (15 Nm); tighten the bolts final pass to 22 ft. lbs. (30 Nm).
Water pump drive belt pulley and bolts (if applicable). Tighten the pulley bolts first pass to 89 inch lbs. (10 Nm); tighten the bolts final pass to 18 ft. lbs. (25 Nm). "
My question is, what tool do i need to get to measure the ft . lbs. mentioned, or is that completely necessary. Thanks for any help, hopefully the question wont be to embarrassing
Old Mar 26, 2011 | 10:00 PM
Sn0wBa11's Avatar
11 Second Truck Club
They don't have to be torqued just tighten them up really good by hand with a 10mm socket and ratchet. I've never torqued water pump bolts lol
Old Mar 26, 2011 | 10:02 PM
Laugh if you must, i just wanna make sure i get this done right, anything special go on the threads when i install the new one?
Old Mar 26, 2011 | 10:12 PM
fredkj3's Avatar
dry should be fine you could put some med grade lock tite... not the red permanent....
Old Mar 27, 2011 | 12:23 AM
00ChevyScott's Avatar
Wearin' da big hat
You would use a torque wrench.
They're very useful tools, one that should be in every ones tool boxes. Is is absolutely necessary for this job? No, and I haven't used one when changing a water pump ever. But I have used one for many other things in an engine. They can be had for as cheap as $20, and functions very similarly to a regular ratcheting wrench.
Old Mar 27, 2011 | 10:37 AM
Thanks for taking me by the hand lol, do i have to replace the fan clutch also? Truck has about 150,000 on it
Old Mar 27, 2011 | 10:48 AM
Atomic's Avatar
I have a gauge for that
Torque wrench is what you need...I have never used one on waterpumps, but you can get a $20 walmart cheapo or a $400 snap-on that nearly does your laundry....I prefer the German torque wrench version, goodentight.
Old Mar 27, 2011 | 11:01 AM
Wearin' da big hat
Your fan clutch is probably fine. As long as you're not having problems with it, I would leave it as is.
ferrellrooster
Mar 6, 2025 03:22 PM
5.3Caprice
Nov 7, 2015 08:56 PM
USMCvet0311
Aug 1, 2015 07:45 AM
Castro45
24
Jul 31, 2015 07:13 PM
bsn1989
Jul 16, 2015 08:20 AM
