switching synthetic oils?
Old May 2, 2009 | 10:59 PM
LS1TRUCKGUY's Avatar
Default switching synthetic oils?
is there a problem switching from royal purpil to mobil one?
also, how many miles are you guys going between oil changes on both oils?
Old May 2, 2009 | 11:17 PM
sonoma43's Avatar
I switched from RP to pennzoil platinum with no issues and change it every 3k
Old May 2, 2009 | 11:49 PM
viciousknid's Avatar
Where's the Beef?
huh? like your motor is going to start having withdrawals?
You'll be fine.
I do 5500-6000 miles between changes
Edit: I use Valvoline Syntec 10/30
Old May 3, 2009 | 03:26 AM
CashDudeHomie's Avatar
No worries, but Pennzoil Platinum has been shown to be better than Mobil 1 and it's about 5 bucks cheaper for 6 qts. I am switching from M1 to PP on my next oil change tomorrow.
Old May 3, 2009 | 02:28 PM
slow.8's Avatar
do you also change it every 3k with synthetic oil? what a waste of money.
Old May 3, 2009 | 03:05 PM
LsxCody's Avatar
Ur wasting synthetic if ur changing at 3k miles
Old May 3, 2009 | 03:12 PM
53bowtie's Avatar
I would think you would be fine. The only time I have seen trouble is on higher milage engines switching form regular oil to synthetic which tends to make them use a little but switching between two synthetics would be fine I would think.
I run BG 0w30 in mine but you have to get it from a shop as they dont sell to the general public. I go 15,000 miles between changes still changing the filter every 3k.
Old May 3, 2009 | 06:09 PM
sweet. thats what i wanted to hear. thanks guys
Old May 3, 2009 | 11:19 PM
SilverDog's Avatar
Don't worry Mobil 1 is better then Royal Purple and I have even heard some people say Pennzoil Platinum is better then Mobil 1. ASK BOB.
Old May 4, 2009 | 05:51 AM
04Burban's Avatar
I used M1 since I bought the truck in 04, I changed in 07 to RP and noticed a difference. My GF used that PP in her SSS and didn't like it after using RP...her next oil change she's going back.
For the ones that change their synthetic at 3k, you can take my advice or not: PLEASE STOP!
