rear main seal in 5.3 ?
Old Nov 2, 2006 | 07:07 AM
shanekennedy's Avatar
Default rear main seal in 5.3 ?
anyone had problems here
i have a 5.3 from a 04 buick rainer being transplanted to a 68 camaro
i have a friend w/ a 04 rainer who had rear mail replaced & his mechanic said this was a known problem w/ these engine
just curious how widespread a problem it is & whether i should replace seal before i install engine
Old Nov 2, 2006 | 07:14 AM
sroach20's Avatar
122,000miles with no problem. if i had the engine out i would replace it just to be on the safe side.
Old Nov 2, 2006 | 07:33 AM
Batman WS-6's Avatar
my 5.3 leaks a little bit, as does my LS1.
Old Nov 2, 2006 | 08:11 AM
TigerFan187's Avatar
I just pulled the LS1 out of my truck to swap with a 408 and it had been leaking a little.
Old Nov 2, 2006 | 08:47 AM
silver-mod-o's Avatar
Hunt&Fisherator
no leaks in my '00 so far... almost to 100K
Old Nov 2, 2006 | 09:10 AM
Bish's Avatar
No leaks on mine at 181K+
Old Nov 2, 2006 | 09:19 PM
budhayes3's Avatar
PT's Slowest Truck
I haven't heard of any common problems with them from the factory, but I have read that if they aren't installed with the proper tool, problems/leaks will more than likely occur.
Old Nov 3, 2006 | 10:33 PM
closet red neck's Avatar
I heard that the old style rear seals leaked alot and they(GM) redesigned them to fix this problem. I don't know if this true or not.....but if you have the engine out, then I would R&R it.
James
5.3Caprice
Nov 7, 2015 08:56 PM
DarkhorSe_SS
Aug 20, 2015 08:58 AM
Ketis
Jul 23, 2015 12:37 PM
kdw8888
Jul 9, 2015 10:52 PM
