rear main seal in 5.3 ?
anyone had problems here
i have a 5.3 from a 04 buick rainer being transplanted to a 68 camaro i have a friend w/ a 04 rainer who had rear mail replaced & his mechanic said this was a known problem w/ these engine just curious how widespread a problem it is & whether i should replace seal before i install engine |
122,000miles with no problem. if i had the engine out i would replace it just to be on the safe side.
my 5.3 leaks a little bit, as does my LS1.
I just pulled the LS1 out of my truck to swap with a 408 and it had been leaking a little.
no leaks in my '00 so far... almost to 100K
No leaks on mine at 181K+
I haven't heard of any common problems with them from the factory, but I have read that if they aren't installed with the proper tool, problems/leaks will more than likely occur.
I heard that the old style rear seals leaked alot and they(GM) redesigned them to fix this problem. I don't know if this true or not.....but if you have the engine out, then I would R&R it.
James |
