Pacesetter LTs installed!!!
Old Feb 5, 2007 | 09:21 AM
12secSS's Avatar
Thumbs up Pacesetter LTs installed!!!
I installed my Jet-Hot coated Pacesetter LTs this weekend. Install was a breeze, just lifted the truck enough to slide under the transfer case's cross member and the LT slipped in easily from the bottom. I had to replace my Taylor wires with Kragen purchased wires. Hey, they have a lifetime warranty, and I can replace them when ever I want so long as they are not burnt. My father came over to help me re-arrange the stock dual "Y-Pipe" or the 6.0L, we kept the cats. Sounds stayed pretty much the same, due to the silencers and cats remaining. I had already tuned the truck with the small cam (212/218), so the added power was not as noticeable as on a stock tuned vehicle, plus the test drive was with 87 octane. It was running a bit lean, about 5%, the idle was off a little and the shift points were now too high. I adjusted all of this and the truck runs much better. I just filled it up with 91 octane this morning, so I will see what difference it makes with better gas. You can feel that there is more power throughout the power curve. I will get pics up of how we rerouted the stock exhaust later tonight, it is not pretty but works. I will need to "coat" the exposed welded areas for when we go off-roading. Now all I need to do is get are the E-Fans, U/D Pulley, and possibly a different cam.
__________________
George P. Lara: 2001 Camaro SS #0391
HPTuners for '98-'02 F-Bodies & '99-'02 Trucks
Jenibella Racing Crew Chief
1998 Camaro Z28: 9.94 @ 137, 1.45
Old Mar 1, 2007 | 10:15 AM
Scott Mills's Avatar
Do you have any pictures? I have the same truck and cant visualize how these headers will fit with the tranny and transfercase.
Old Mar 1, 2007 | 01:54 PM
blown3qtr's Avatar
pics
Old Mar 1, 2007 | 01:56 PM
12secSS's Avatar
Here are the pictures.
Old Mar 1, 2007 | 02:37 PM
Gosh damn that some tight fitting on those Cats, do you ever have a problem with them knocking any crossmember or anything?
Old Mar 1, 2007 | 03:20 PM
12secSS's Avatar
Yeah, I had to modify the hanger behind the cat to hold those pipes up higher. I am thinking of getting (in the future) some 3" mandrel bends and redoing the exhaust to the mufflers. It is very quiet as it is right now, but at 2000 rpms and up, it moves. Funny thing is, it backs second at WOT pretty good now. Scares the commuters.
Old Mar 1, 2007 | 05:55 PM
oneslammedgmc's Avatar
12secSS, how long did it take you to install your headers? I'm fixing to put mine on this weekend and I was just curious how long it might take.
Old Mar 1, 2007 | 05:59 PM
RoosterMcCandles's Avatar
FWIW, mine took about 4 hours...
Old Mar 2, 2007 | 09:07 AM
12secSS's Avatar
Due to mine being a 6.0L with no available "y-pipe", because of the stock "true dual" design, I had to fabricate my own "y-pipe". Otherwise, yes about 4-6 hours if you have a 4.8L/5.3L and the ORY Pipe.
Dirtywhite
Aug 5, 2015 04:10 PM
Chiphead
Aug 1, 2015 04:43 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
ssierra08
Jul 15, 2015 06:40 AM
