OVH motor. extra bolt
Old Sep 4, 2020 | 11:16 AM
  #31
metalchip's Avatar
5 Year Member
Default Yup Yup
Is The Ac compressor mounted?
Ae the lines hooked up?
Hello,
Yes the AC is on with 15mm head size bolts. And I did not remove the lines off of the pump so yes, the lines are hooked up.
Thanks,
The EXTRA Bolt has a 13mm head size.
Old Sep 4, 2020 | 11:42 AM
  #32
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by metalchip
Hello,
Thanks,
The AC lines is the only place I know on a 2002 engine that uses a 13 mm head on the Bolts and the nuts retaining the lines. That's why I asked.
The fender braces use a 13 mm but have a built in washer and are shorter in length. Same with hood bolts but they are body color.
Old Sep 4, 2020 | 11:53 AM
  #33
metalchip's Avatar
5 Year Member
Default OK thanks
Maybe I should look again at the front axle as I removed the right axle tube to replace the axle seal.
But thanks
The story continues---------------
Old Sep 4, 2020 | 01:00 PM
  #34
arthursc2's Avatar
That fan leaves a lot of area exposed
4.8thatcould
May 30, 2017 02:06 AM
dirt track racer 81
Sep 8, 2006 07:44 PM
Colby 04
Jul 7, 2006 03:15 PM
SmOkA2k3
Jun 27, 2006 10:50 PM
