OVH motor. extra bolt
Old Sep 2, 2020 | 11:09 PM
  #21
metalchip's Avatar
5 Year Member
Default oops, 1.5 inches
Originally Posted by metalchip
Hello,
Well 3 months ago I pulled the 5.3 out to OVH it. After many delays I started to reinstall and for the life of me I could not find where this bolt came from. Hoping to find where the bolt went, I put everything back on, but no luck. My truck is in my signature.
I found the bolt in the bag for the driver’s side front along with the power steering mount bolts. So, it should go in that top side general area. The picture shows it with a larger power steering mount bolt.
It has a shallow head, 2 ½” long and has 8mm-1.25 thread. It did not have any road grime-dust on it.
NOT 2 1/2" BUT 1 1/2" CORRECTION MADE
I replaced the front right axle seal and the front right wheel hub when I had the engine out, but the bolt would not have ended up in that bag of bolts.
This is the 1st LS type engine I have pulled out so any help would be appreciated.
Thanks
Good catch--OOpooterSS.
Old Sep 2, 2020 | 11:15 PM
  #22
metalchip's Avatar
5 Year Member
What year is the truck?
Looks like an Ac compressor line to Compressor bolt?
Hello,
2002, it is in my signature. I did not break open the AC lines.
Maybe it is the fuel saver bolt? Leave it out and they is less weight to haul around?
Thanks
Old Sep 2, 2020 | 11:20 PM
  #23
metalchip's Avatar
5 Year Member
Default Nope
Originally Posted by arthursc2
That looks like a radiator upper bolt to me. Did you pull the radiator by chance?
Hello, no I left the radiator in. Removing the water pump gives just enough room to get by the rad. top piece.
Old Sep 2, 2020 | 11:43 PM
  #24
arthursc2's Avatar
Yeah I went and looked at my truck (02 5.3 Tahoe 4x4) to try to help
I thought it might be a motor mount bolt but all those are marked 10.9
I thought was the idler bolt but it's marked 8.6 (never heard of that grade before)
so I dunno what it is, but if it's working, roll with it 😂
Old Sep 3, 2020 | 05:11 AM
  #25
randeez's Avatar
Nevermind, didn't read
Old Sep 3, 2020 | 08:57 AM
  #26
metalchip's Avatar
5 Year Member
Default close
Originally Posted by randeez
just looks like one of the bolts for the valley or rear cover
Hello, close but not same length.
I will keep looking!
Thanks
Old Sep 3, 2020 | 12:18 PM
  #27
00pooterSS's Avatar
Is this a hole here that takes a shorter bolt than the other bracket bolts?
Old Sep 3, 2020 | 09:46 PM
  #28
metalchip's Avatar
5 Year Member
Hello, I will take a look in the morning, thanks.
Old Sep 4, 2020 | 10:09 AM
  #29
metalchip's Avatar
5 Year Member
Red face More pics
Hello,
Here are some pics of the power steering mounting and my home made fan shroud.
There are 3 bolts on top and 1 on the bottom that go in from the front. Only 2 top ones are in the photo but there are 3.
And 2 [studs with nuts] on the back side of the PS pump and 1 15mm bolt in the block for the rear bracket.
The red wire is a extra frame to block ground.
I am still looking to where to put the EXTRA BOLT! It makes me feel old, I remember that "was an odd place for a bolt, I am sure I will remember that!" WRONG!!!
All the PS bolts are in, they all have 15mm wrench size head bolts, not the 13mm I have EXTRA.
Thanks for looking and your help.
Power Steering bolt [larger] and the EXTRA BOLT
front
Back PS bracket showing 2 of 3 15mm bolts
bottom
bottom front
Ford Torino fan
Home made shroud
Old Sep 4, 2020 | 11:02 AM
  #30
1FastBrick's Avatar
Custm2500's Rude Friend
Is The Ac compressor mounted?
Are the lines hooked up?
