Am I sweatin' it too much?
Old Jul 3, 2006 | 12:56 PM
Colby 04's Avatar
Default Am I sweatin' it too much?
Here's the pic:
Driver's side motor mount bolt broke, it's on the frame side of the motor mount at the front. I've got all the other 5 in and torqued to spec, and I was able to thread a nut on about 2-3 threads of the broken bolt and torqued it to ~65lb/ft.
should that broken bolt be removed(nearly impossible....yes, easier said than done), or will it be ok?
I've thought about having the nut welded to the broken bolt, that would then make it a bolt again, but I'm not sure how to tackle that since it's only threaded into the nut about halfway.
I almost cried when that happened
Old Jul 3, 2006 | 01:15 PM
dry_kill's Avatar
stop worrying about it, it should be fine, if u want some extra assurance, just take it to a shop and just have them weld the top of the nut to the stud and it'll be fine
Old Jul 3, 2006 | 01:19 PM
j.whitten's Avatar
I think if you were able to torque it down it will be fine, maybe a aircraft nut or a tack like stated before. You did say there are 5 others holding it in
Old Jul 3, 2006 | 01:23 PM
Colby 04's Avatar
yup, the other 5 are fine, the one that broke is the front driver's side bolt
Old Jul 3, 2006 | 02:15 PM
Gran Patron's Avatar
Hey Colby, I think you should be fine. As long as the other 5bolts are secure the motor should be sitting pretty tight already.
Old Jul 3, 2006 | 02:23 PM
OKLAGMCRUISER's Avatar
nope..you have to sell me the truck for a dollar now and take my heap off my hands!!!
I agree with the others taht if you can get the nut welded on it may be better for your conscience
Old Jul 3, 2006 | 02:29 PM
Colby 04's Avatar
I'll sell you this for a dollar
It's difficult to get to the stud/nut, but at least it's on the front side of the mount...I'll see if someone can throw a tack on it
Old Jul 3, 2006 | 04:43 PM
Onyx 02's Avatar
If you're worried about it, tack weld a nut on there and remover the bolt and replace it w/ a new one.
Old Jul 3, 2006 | 05:16 PM
FarmerBeau's Avatar
Sexy Party Mod
with his luck, hell snap that one off too.. DOH... I didnt mean it Colby. ***Knocks on Wood***
Old Jul 3, 2006 | 05:20 PM
Colby 04's Avatar
the question is, should I be worried about it?
