ls1 fans
Old Apr 14, 2005 | 12:24 PM
bluecajun5.3's Avatar
11 Second Truck Club
Default ls1 fans
hey guys. i will be installing my ls1 fans with the nelson harness soon. i have read about people hooking up a manual toggle switch to activate them when ever they wanted to. my question is after i get everything wired, will i be able to activate the fans to kick on with the manual toggle switch without the pcm being programed for the fans? thanks....
Old Apr 14, 2005 | 08:31 PM
04Z71SATX's Avatar
im interested in that as well. good thread...can you fill me in with any info you find? im looking to do the exact same thing with my fans.
Old Apr 14, 2005 | 08:43 PM
jow02327's Avatar
yes i just did this by using putting a scotch lock on the blue wire that comes from the pcm and run a wire to a switch and then from the switch to a ground wire. that away they will be controled by the pcm and also by the switch
Old Apr 14, 2005 | 11:14 PM
greentahoe's Avatar
I have mine setup that way, but Im not sure if it would work if the perameters in the PCM werent set to recognize the fans.
Old Apr 14, 2005 | 11:23 PM
quicksilverado's Avatar
The toggle switch will turn the fans on. It does'nt matter if the pcm is programmed to turn them on or not.
Old Apr 14, 2005 | 11:25 PM
jow02327's Avatar
you can wire it state to the switch and then you have complete control over when they come on and go off.
Old Apr 15, 2005 | 09:11 AM
thanks for the replies guys, it will only be like this for a lil while until i drive it home to get it tuned. just wanted to know if it could work without the pcm programed... thanks
i'll take your work quicksilverado. i hope it works.
Old Apr 15, 2005 | 09:12 AM
sry i mean word*
CD82
Oct 23, 2015 07:32 AM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
Dawas
Sep 20, 2015 12:00 PM
FormulaZR
Sep 14, 2015 05:23 PM
