Which intake manifold and throttle body
Old Dec 2, 2011 | 03:33 PM
SSmikeSS's Avatar
Default Which intake manifold and throttle body
I'm looking to change my intake manifold, fuel rails, and throttle body this winter.
Take a look at my mods in my sig and let me know what you think would be a good match for me?
I've been looking at the Vic jr and the Pro-flo Xt. I'm not really into the Fast products and holley doesn't make their intake for my heads.
Also which throttle body should I go with? I'm pretty much clueless with this and I would like you opinions.
Thanks,
Mike
Old Dec 2, 2011 | 05:44 PM
SweetS10V8's Avatar
Ive have personally dyno tested the Pro Flow XT, vic Jr, and FAST LSXRT. I would take another look at the FAST. It made over the Trailblazer SS intake on a boosted TBSS. (See link)
The FAST is a much much better street/strip intake. If your a drag only guy, which your cam/TC suggests that your not, then I would look into the Edelbrock products.
Fast LSXRT Intake Manifold Upgrade - GM High-Tech Performance Magazine
Old Dec 2, 2011 | 06:21 PM
SSmikeSS's Avatar
Thanks for the link.
What did you see with test of the 3 manifolds?
Old Dec 2, 2011 | 11:15 PM
SweetS10V8's Avatar
Basically;
Edelbrocks lose 40-60ft*lbs between 2500-5000 to FAST
Edelbrocks and FAST are similar 5500-6500
Edelbrocks make 5-10 more hp than fast from 7000-7200
Old Dec 3, 2011 | 02:48 PM
SSmikeSS's Avatar
Well, I don't have to worry about 7000+ RPM's LOL
Did you test this on your s10? What size motor?
The Fast is SO expensive though. I would end up spending double the money.
Old Dec 3, 2011 | 10:16 PM
SweetS10V8's Avatar
They were all on the engine dyno.
Vic Jr was on a 5.7L LS1
Proflow and LSXRT was on a 6.0L LQ4
Old Dec 4, 2011 | 04:07 PM
SSmikeSS's Avatar
Why does the Fast Lsxrt cost more than the Lsxr? (I think that's what it's called)
Do you think the Fast still better when using FI?
Old Dec 4, 2011 | 04:34 PM
black00chev's Avatar
Slowest turbo build ever!
The T is taller and has longer runners so I would assume the additional material used would cause the price to be more!
Old Dec 4, 2011 | 04:57 PM
zero2sixT's Avatar
Are you still running the stock intake manifold? If so, I'd swap it out for a 87mm/90mm stock intake.
Unless you're trying to ring out every last bit of power, a fast intake isn't going to be worth the money. Id go to a bigger charger before going to a fast manifold.
Search around for a few boosted setups. People are still making big power with the ls6 manifold and cathedral port heads. And that design has been around for 10+ years.
Old Dec 5, 2011 | 04:07 PM
SSmikeSS's Avatar
I'm still running stock TB and intake manifold.
I am trying to get all I can out of my truck. But the Edelbrocks are $4xx.00 and the FAST is $1300.00. So if I could get a lot more out of it with the FAST than the Edelbrock, I would consider it.
Also the 102mm TB's are drive by cable.
Will the FAST really give that much more power?
